03-07-2020, 01:53 PM | #1 |
BTR valve seal installation
I am going to be starting my cam install in the next few days and am trying to plan everything out before hand. I know well enough things don't always go as planned though.
Anyhow, one of my concerns is with the install method with the BTR valve seals with the separate seat. I was going to buy the install tool BTR sells but I noticed that those are mainly for use when the heads are off the engine. So what did you all use? I have seen some posts of people using a 12mm deep socket and lightly driving them down. But I don't want to tear the seal or mess up the delicate seal spring. What's the safest method?
03-07-2020, 02:11 PM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Buy the BTR tool you can do it with the heads still on
03-07-2020, 02:17 PM | #3 |
Really? I was worried it wouldn't leave enough room for the valve stems. But I could just bring the piston to TDC and let them drop a little right? Nice!
03-07-2020, 02:29 PM | #4 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I have the btr tool if your interested $10 I’ll ship it to you. I went with Texas speed so didn’t need the tool.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-07-2020, 02:37 PM | #5 |
I already ordered it, but I do appreciate it. I used a gift card so it was no big deal. Thanks man.
03-07-2020, 03:06 PM | #6 |
Ok never used it, and is too late to return it so it’s just sitting in my tool box. Good luck with the cam swap.
03-07-2020, 06:55 PM | #7 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Did it with a 12mm deep
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
03-07-2020, 08:03 PM | #8 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
You can bring the piston to TDC and get it done. That's what I did. Also used a socket with no issues to install the seals. Been fine for over 10k daily-driven miles since last May.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
03-09-2020, 02:01 PM | #9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Why new valve seals? Just for the sake of doing it while your in there or do the new springs interfere? Therefore a different style of seal.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
03-09-2020, 07:16 PM | #10 |
I currently have the blue GM beehives with the 1 piece hat style seals. I am installing BTR dual springs for my cam swap and they require the 2 piece seal/seat to not interfere with the small inner spring.
04-11-2020, 10:05 PM | #11 |
Drives: 2014 Camaro 1SS Join Date: Jun 2010
The BTR install tool worked well for me.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
