10-16-2019, 02:40 PM | #1 |
Any idea what my damaged L99 is worth?
I am just trying to get a feel or idea what my L99 semi short block is worth in its current state.
Heads were sold already. So I have it currently with only 7 pistons, and the number 8 rod took some slight scoring damage from the #7 rod when it broke and spun around. According to my engine guy, the #7 cylinder liner just needs a hone as there was some scuffing when the skirt broke from the rod smashing it, but no deep scores. Crank is perfect. I would guess anyone I sold it to would likely just replace completely the pistons and rods anyhow. But as a block and crank, any idea what this is worth ballpark? 150k miles and has the LS1 style 'Muscle Car Conversion' pan, pickup tube and windage tray on it now. I took the L99 pan for the LS3 in my car now. My original goal was to slowly turn this into a forged/stroked monster, but money is getting tight since the swap.
10-16-2019, 06:49 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Make more to part it out at this point, as a hole it's only worth the parts a guy might want from it.
200 as hole , part it out and 300+ maybe
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
10-16-2019, 06:54 PM | #3 |
Just saying a guy could get a used iron short block for 200 to 300 with no damage , so I'd sell the high value parts separate and make most money that way
10-16-2019, 07:42 PM | #4 |
Damn.
For a good 6.2 aluminum block and crank? I think I need to lower my expectations a bit. If that low, I honestly would rather just keep it and turn it into something special.
10-16-2019, 07:49 PM | #5 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I got $800 for my short block with a spun rod bearing.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-16-2019, 07:55 PM | #6 |
Yeah, I was under the impression the 6.2s held a premium, assuming no windows added to the block.
10-16-2019, 08:25 PM | #7 |
I put it on craigslist for $1k... guy came with 8 cash...
