08-24-2018, 10:12 PM | #1 |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
The gods do not want me to have a 10 second car
Finally got back to the strip. What a bad night lol. I was literally 6th in line to go when someone blew up on the track. Took a full HOUR for them to clean it up. 2 cars go down, then a 9 second civic blows a hole in the block and leaves oil down the whole track. Another hour. I finally got ONE run in before I had to leave. Got a good burnout, dead hooked off the line, but did chirp and sway some between the 1-2 and 2-3 shift. All I want is a damn 10.9x slip haha.
Notes for next time though: Longer burnout Use less than a half tank of fuel Pull rear seat maybe
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
08-24-2018, 10:23 PM | #2 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
So close! You will be there soon enough. Better DA and you are home.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
08-24-2018, 10:46 PM | #3 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Can't get much closer than that. I am hoping to see the 10s in a couple of weeks also. Just added the lt4 fueling and headers to the Whipple, going in for a tune on Tuesday. 11.17 with just the Whipple and canned tune from Whipple at 4,200 DA. The extra fuel and custom tune should get me into the 10s.
08-25-2018, 06:33 AM | #4 |
Huh, with my Maggie my first pass was 10.91@129.88 and the second pass was 10.82. Probably need a converter to get that launch into the 1.50's or lower and then you'll be in the 10.70's or 80's. Good luck and you'll get there.
08-25-2018, 06:48 AM | #5 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
I know the feeling. However, you’ll get there.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
08-25-2018, 07:31 AM | #6 |
I can’t be too upset with it. The car has more for sure. Just sucks that I was only able to get one run in. It’s just ironic that my goal is to just have a 10 second time slip on this car and one thousandth of a second would have done it haha.
08-25-2018, 07:34 AM | #7 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Damn, so close Phil! It's definitely in the cards for you. Next trip you'll get it!!
08-25-2018, 08:18 AM | #8 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
You are there,only a matter of time.
Early Congrats!!! ,now get a converter and fly! ,you know the stock one is gonna screw up anyways if its not already. Have you been doing any trans tuning?
08-25-2018, 09:02 AM | #9 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
Don't let things you cant control upset you; you have a fast car. The slip doesn't need to tell you that bro!
with the right air you'll have a 10.9* no big deal; run with a 1/4 tank
08-25-2018, 09:51 AM | #10 |
You must have quite a bit of Torque management in the trans tune yet. 127mph with a 1.62 60ft should be a 10.7 imo. Pray just had a bolt-on car run 11.1 @ 123 with a 1.6 60ft in 2500da yesterday. You have 4mph on that car yet only ET 1 tenth quicker on the same 60ft. Not knocking, just saying I bet you have a bit left in it with tuning. Either way it will go 10's.
2016 NFG 1SS A8
08-25-2018, 10:35 AM | #11 |
Wow, I did not see this run, and when I went to ask you how it went, you seemed to be gone. Frustrating I know to miss your goal by a thousandth, but at least take some consolation that it's getting faster. The breakages and very long cleanups were a pain for sure.
08-25-2018, 10:39 AM | #12 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Nothing more irritating than spending all day at track after driving 3 hours to get there just for some POS junkyard build to spill oil all over track and spoil everyone's fun
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
08-25-2018, 11:35 AM | #13 |
Still a good pass. So keep trying to improve your 60 ft.
08-25-2018, 03:50 PM | #14 | |
Drives: 1987 Buick Grand National Join Date: Mar 2016
