Old 01-23-2019, 09:37 AM   #29
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
Originally Posted by mdhopt36 View Post
Friggin' Upside down.
Come on, Chris !!!
I'll do better next time!
CamaroChriSS is offline   Reply With Quote
Old 01-23-2019, 09:53 AM   #30
drperry
Drives: Chevy Blazer
Originally Posted by JamesNoBrakes View Post
This would make sense if you were driving through a foot of two of snow with a VW van or something.
The car will become a snowplow long before you reach snow deep enough for this to make a difference. These cars are way under-tired with something like 225s.
Unless you're tracking it, you'll be fine, lol.
The size recommendation is only if you're running dedicated winter tires...
Skinnies have more grip on ice, too, not just for cutting through the snow. Ground pressure is more effective for ice grip than a couple more tread blocks.
Dry pavement is where the wider tires provide more grip.
Sent from my SM-G965W using Tapatalk
drperry is offline   Reply With Quote
Old 01-23-2019, 01:18 PM   #31
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
More studs in a concentrated area would have more grip on ice, that's how studs work, but wider is better for traction on smooth (ice) surfaces. Not sure how you think the opposite is true. Ice isn't some mystery substance, the right winter tires will grip better and treat it more like a dry road surface (although it won't ever quite get there). Wider will still give you better traction. What you are talking about has only two valid points IME, compressing a bunch of snow with a hard surface beneath, for traction, and concentrating studs, which has some validity, but with the tire compound also providing grip you still benefit with wider tires.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 01-23-2019, 04:16 PM   #32
dunedon
dunedon's Avatar
Drives: 2018 Hot Wheels 2SS Convertible
Originally Posted by Vtor_ZL1 View Post
You know seats are height adjustable ?
was that to me? Seats are back and low just as I like them
2018 Hot Wheels SE, Convertible, V8, 2SS, A8, MRC, Nav, NPP (WDXNTP)
1100 - 28/05/18 | 2000 - 31/05/18 | 3100 - 05/06/18 | 3400 - 15/06/18
.TPW - 16/07/18 | 3800 - 16/07/18 | 4300 - 17/07/18 | 4200 - 24/07/18
5000 - 25/07/18 | 6000 - 31/07/18 | XPEL - 01/08/18 | HOME - 13/08/18
dunedon is offline   Reply With Quote
Old 01-23-2019, 07:18 PM   #33
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
This is my Camaro in the snow... Under the car cover. Just finished shoveling around it... It is trapped in a corner, behind there are some cedar and in front is the garage... What a PITA to move to snow around haha.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 01-24-2019, 01:19 AM   #34
IAI80
Drives: 2016 1LT V6 A8
I routinely leave mine in a work parking lot for a few days at a time. While I was gone it was freezing rain that changed over to snow this time. The parking lot has a gentle, not all that noticeable slope to it. To back out of the spot I was in though went against the slope. The car wouldn’t do it. Luckily, nobody was parked nose to nose with me. Going forward I got out with no problem. It was after midnight and 9 degrees. I didn’t need problems. From now on, I will make a point during the winter of parking only in spots where I do not end up forced to either back up or pull out going against the slope....may the slope be with me.
IAI80 is offline   Reply With Quote
Old 01-24-2019, 03:26 AM   #35
5150777
5150777's Avatar
Drives: 2019 Satin Steel Metallic ZL1
Mine
5150777 is offline   Reply With Quote
Old 01-24-2019, 08:38 AM   #36
drperry
Then adding weight wouldn't increase traction at all.... Which it does... Because of added ground pressure.
Going from a 525 wide tire to a 245 wide tire gave me more traction on pure ice, lol.
Same reason some folks with unloaded dually's will run singles in the back... Better traction on ice.
Same reason nobody runs 15.5 or 18 wide tires on their truck in the winter, unless they can't afford winter setups, lol.
Same reason 11" wide semi tires turn better on ice than 385 wide semi tires... All with the same tread pattern, lol.
But I'm also going off my personal experience and everyone I know, so it's probably a skewed view compared to your sources.
Old 01-24-2019, 09:39 AM   #37
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
Is that with stock tires?
2017 camaro SS A8
FBO With all porting and tuning done by PRAY
70chevelleSS is offline   Reply With Quote
Old 01-24-2019, 10:17 AM   #38
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 01-24-2019, 12:11 PM   #39
JamesNoBrakes
Drives: 2SS 1LE
Better traction on ice? Or better traction on snow when you compress it against a hard layer (ice or road beneath).
Have you tried braking on ice with skinny tires and no studs? If not, you are in for some fun. Tried turning across an intersection with lateral forces acting on your car? I'm not doubting you having driven through snow, but driving on ice constantly, I am. To a degree, on snow, you can increase traction by increasing weight and compressing the snow against a hard layer, assuming your tread compound is good for winter. We don't have the kind of weight over the axles in a rear-wheel-drive car to ever approach the starting-traction of something like a box-truck or even an SUV, but that's not where the greatest danger is, it's from sliding left or right and not being able to brake.
2018 2SS 1LE
2023 Colorado ZR2
Old 01-24-2019, 01:34 PM   #40
detamble13
detamble13's Avatar
Drives: 2011 2SS/RS LS3 VR
i
detamble13 is offline   Reply With Quote
Old 01-24-2019, 04:54 PM   #41
BlakeR
BlakeR's Avatar
Drives: 1ss
BlakeR is offline   Reply With Quote
Old 01-24-2019, 05:36 PM   #42
Silverado57
Silverado57's Avatar
Winner! No more calls please!
Originally Posted by BlakeR View Post
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
