03-13-2020, 09:59 AM | #1 |
BITCHN Camaro
Drives: SOLD! Back in the looking zone... Join Date: Feb 2015
K&N Cold Air Intake Kit: No ECU Tune Required
Has anyone installed the K&N CAI? It's by far the best priced system I've seen so far (~$300 on Amazon) and claim that no ECU tune required. Interested to hear if anyone has this and if they're happy with the results...
BITCHN
03-13-2020, 11:03 AM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I'm interested in this as well. Looking at the K&N myself
03-13-2020, 02:00 PM | #3 |
Drives: 2019 Satin Steel Metallic Join Date: Nov 2010
I have the K & N Typhoon on my '19 RS and have had no issues so far. I'm sure a tune would optimize the overall performance, with or without the CAI.
03-13-2020, 04:20 PM | #4 |
Drives: 2018 Chevrolet Camaro RS Join Date: Mar 2019
I have had the K&N Typhoon installed on my V6 now for over 6k miles. No issues. I have had a tune included after installing an 80mm throttle body and ported intake manifold just under 1k miles ago. Still no issues.
03-14-2020, 10:18 AM | #5 |
Drives: 18 2LT RS V6 M6 Vert Join Date: Dec 2019
04-11-2020, 02:05 PM | #6 |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Cold Air Inductions
Has anyone heard anything about Cold Air Inductions? Their kit seems a little better than K & N. From what I can see...
https://www.coldairinductions.com/sh...extured-black/ |
04-11-2020, 02:19 PM | #7 |
Drives: 2012 Camaro SS Join Date: Dec 2019
K&N, cold air and Roto fab are some of the best. Get anyone in your price range and usually don’t need a tune with any of them.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-13-2020, 08:39 AM | #8 |
Drives: camaro rs Join Date: Feb 2020
Your tune needs to rescaled to take advantage of the larger intake of air. Just because you don't get a CEL doesn't mean you don't need a tune.
04-16-2020, 01:18 PM | #9 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
the maf measures airflow and if the specs around it are within tolerances of the stock tune, then the amount of air that is getting to the engine is fully accounted for whether you're in the stock tune or not.
Tunes for intakes are needed if you're outside of those tolerances and so the constants that the tune uses to determine air flow and density end up being wrong to varying degrees. Any other change in performance from a tune has nothing to do with the intake. Our stock intakes are not anemic or restrictive (especially if you've dropped in a gauze filter). The maf is more than capable of measuring the air getting to the engine regardless of how much air that is (at least in non-FI) so long as the constants haven't changed and when they do, it doesn't take much for it throw a code. tldr; if you throw a code, you need a recal of your tune or fix whatever installation mistake you made. If you dont, then you're fine. CAI's are for show more than function in these cars since the stock intake is a CAI. You're really just swapping filters. |
04-17-2020, 08:39 AM | #10 | |
04-17-2020, 09:38 AM | #11 |
The gm intake specifically alters the diameter around the maf and tells you that the intake requires a recal to compensate. Not actually triggering a code with it is an exception.
For intakes that are marketed to not require a recal, they mimic the air bridge diameter and position very closely to stock. Any variation in the AF at WOT with them would not be on par with the GM intake or any other intake that mentioned that you needed a recal for. that's an apples to oranges comparison you're making. |
04-23-2020, 12:33 PM | #12 |
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
I have had only K&N in all my Camaros. Love it! 2011 2SS, 2012 2SS, 2013 2SS, 2017 V6, 2018 V6 and now my 2020 2SS.
Easy install, great price.
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
