07-28-2019, 08:05 AM | #15 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
I run 0W-40 ESP Dexos 2 which is made for street and track use. New factory fill for LT1 and LT4. I changed it at 4,000 miles and 2 track days and it still looked like it had some life left. More expensive ($110ish for 12 qts on Amazon), but u don't need to swap it out for track and DD. Keep it in, change when your comfortable doing so
07-28-2019, 09:06 AM | #16 | |
Thank you Al Oppenheiser!
That said, I would recommend getting some data to prove this is worthwhile. Doing some Blackstone lab tests to verify the condition of the oil and motor (must include TBN in your tests):
All of this will cost you about an oil change or so ($130). It is most likely that tests 2 and 3 will be identical to within the margin of error of Blackstone's capability. Telling them what you're doing, they may be able to give you some insight into the process. |
07-28-2019, 08:21 PM | #17 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
My old/beater Tahoe and old Skidsteer love my 2nd hand oil out of the Camaro (With new filters of course)
07-28-2019, 09:09 PM | #18 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
I'm pretty sure the new ESP oil is one you can use on both street and track.
07-28-2019, 10:31 PM | #19 | |
Which is what I use, and still change my oil after 4(ish)hrs of track time, and reuse that oil in my beater(s)
07-29-2019, 09:32 AM | #20 |
Drives: '18 Black SS 1LE; '01 Corvette Z06 Join Date: Nov 2018
M1 Dexos-2 0W-40 track and street.
07-29-2019, 10:35 AM | #21 |
Drives: '18 1SS 1LE Join Date: Sep 2017
OP has a blower, so the 15w50 might be his best track oil.
'18 1SS 1LE Black, PDR
