05-26-2023, 12:57 PM | #1 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Warm Up
Do you guys/gals always start your car and let it warm up a bit before taking off, or do you just fire it up and go? Not specifically talking about cold temp driving. I've noticed that if I just get in my car, fire it up and go it will be very jurky, kind of spit/sputter for the first few seconds after which it's just fine. If I let it idol a few seconds till the idol settles down it's fine.
Just never really had to do this with any other vehicle. Tahoe I can get in, turn the key and go. |
05-26-2023, 12:58 PM | #2 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
My car does the same, but I usually warm it up before I go to work. Like you I wait for the RPM's to settle if I plan to go right away.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
05-26-2023, 01:07 PM | #3 |
Drives: Camaro ZL1 1LE M6 Join Date: Mar 2023
I start mine up let it idle for a min or so while I'm plugging in my phone and decide what type of music I want to listen too, by then my temp gauge starts rising (which happens fairly quick) and I head out. I haven't had any issues with hesitation or lugging and been doing it this way for years. I don't really get on it until the tires are at normal temp and my oil temp is where it normally runs.
ZL1 1LE
05-26-2023, 01:08 PM | #4 | ||
Just seemed odd to me that I can get in my V8 Tahoe fire it up and go and never have anything like that. Quote:
05-26-2023, 01:12 PM | #5 | |
05-26-2023, 01:32 PM | #6 |
05-26-2023, 01:41 PM | #7 |
If you want a nice smooth 1-2 shift. Let it warm up. Manually pop it into 2nd for at least 15 seconds. Then I do it one more time for the hell of it. That’ll fix the 1-2 shift jerkiness.
05-26-2023, 01:44 PM | #8 |
05-26-2023, 04:55 PM | #9 |
Drives: '23 Sharkskin Gray LT1 RS "JAWZ" Join Date: Aug 2022
In all my cars, I have always waited at least until rpms idle down. In the winter it's usually a good 2-3 minutes or until the front defrosters makes it easier to scrap off the ice.
05-26-2023, 06:54 PM | #10 |
I normally do as well. Just happen to take off a couple times right away the past week. Winter I always remote start my vehicles and let them run a few minutes.
05-26-2023, 08:01 PM | #11 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
After initial start up , I let her idle a few minutes, then I drive low RPMs , til the oil temperature is above 160 deg. Then I drive normal
2023 ZL1 A10 Shadow Gray Metallic
05-26-2023, 08:25 PM | #12 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
I noticed the same thing and this will happen even after I've waited for the RPM needle to settle. It will jerk when letting off the clutch but goes away once I gas it. Weird.
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
05-26-2023, 08:52 PM | #13 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
This is 2023 we have fuel injection not a carb, in the days of old you had to let the engine warm up because you had a choke. Computers take care of air fuel mixture now.
05-26-2023, 09:02 PM | #14 |
Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
So no matter warm or cold ambient temps, I always let the car idle for at least 3 minutes or so. Luckily I have some quiet roads by me so I putter around and shift at less than 2,000 rpm until the oil temp reaches at least 150 degrees. After that I drive a little more "normal" but still don't give it the beans until I'm at 200 on the oil.
I've always believed in letting a car reach full operating temp before pushing it. Naturally on a manual car, this helps the shifts smooth out as well. The trans is definitely notchier when cold, but that's to be expected. I can still get really smooth shifts even when it's ice cold though. |
