01-20-2022, 03:35 PM | #1 |
Drives: 2020 camaro zl1 1le Join Date: Oct 2020
2020 ZL1 1LE Valve Springs
Im A little pissed today. 2600 miles on my 2020 ZL1 1le and yesterday I took it out because I couldnt get may software to update cause the stupid radio stays on for 5 min if you dont update and a valve spring on cylinder 4 broke and bent one or two of the valves. Now I have to pull off the headers and complete exhaust to put stock crap on so the warranty would cover it. GM Service bulletin: any zli built between 6/20 and 9/20 have bad valve springs. CRAP
01-20-2022, 04:20 PM | #2 |
Drives: 2018 ZLE Join Date: Feb 2018
How many times can GM get the valve springs wrong? This has been the case for years. Crazy to me. Good luck with the repairs. Thankful its not worse.
01-20-2022, 06:44 PM | #3 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
On a side note, hopefully they won't realize you are tune and try to deny your warranty claim. I suppose it being a service bulletin should facilite your repairs under warranty Sent from my moto g(7) power using Tapatalk
01-20-2022, 07:21 PM | #4 | |
'20 ZL1 1LE A10,
01-20-2022, 07:43 PM | #5 | |
01-21-2022, 05:50 AM | #6 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
01-21-2022, 06:15 AM | #7 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
01-21-2022, 07:07 AM | #8 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
I’m betting the first thing GM will want checked before authorizing any warranty repair will be the tune file. If the checksums doesn’t match their records be prepared for your powertrain warranty being flagged as void.
01-21-2022, 10:45 PM | #9 |
But got he OPs point, what a bummer. I've had my 2010 C6 GS for about 30k miles and 8 years now and the only issues has been so far a master clutch starting to go bad.
02-05-2022, 08:29 PM | #10 |
Drives: 2004 Silverado, 2020 ZL1 Join Date: Oct 2016
My 2020 ZL1 was built 9/12/20. How common is this? Should I be concerned? It's got 3500 on it. I don't think they'd do anything unless a spring breaks.
02-06-2022, 04:04 PM | #11 | |
376 cubic inches of fun
Obviously there was a material quality problem at a supplier. Designing valve train springs is not rocket science, but if the specified material and/or processing is not used, the springs are doo doo. No doubt, GM will not replace springs unless one fails. That's a shame. |
02-06-2022, 08:19 PM | #12 |
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8 Join Date: May 2018
The majority of valve spring failures occur within a few hundred miles, although a few cases have occurred later than that. But at 3500 miles your chances of running into this are pretty much nil.
