09-03-2016, 03:37 PM | #57 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
With all due respect to Glen, I am thinking the black would look good on mine too.
Life after retirement |
09-03-2016, 03:42 PM | #58 |
Retired from Car mfrs....
I appreciate it , but absolutely No need "To respect my opin", we are all different...I just don't want my eye being directed to a splash guard when viewing the car......interestingly, I almost feel the same for the access gas Cap, but the engraving and gloss on the cap is nice. Not sure I'll keep it long term, but we'll see.
09-03-2016, 03:52 PM | #59 |
Drives: 2016 Camaro 2SS Join Date: Jul 2016
There were a pair in the trunk that the dealer did not install in my Camaro, and I have not installed the pair yet, and probably never will.
09-03-2016, 03:58 PM | #60 |
Those weren't the splash guards being talked about here.
09-03-2016, 04:04 PM | #61 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
09-03-2016, 04:10 PM | #62 |
I concur, I actually went so far as the mount black wheels on the Camaro, and sold them because they just looked like black holes when rolling, on my car.
09-04-2016, 07:40 AM | #63 |
Drives: 2020 rally green rs Join Date: Oct 2013
I think the factory ones look good I'm going to order mine in white,since my camaro is white,I just think you want them to blend in and give it a more uniform look,but the black on white did not look too bad.
09-08-2016, 07:38 AM | #64 |
Drives: 2017 NGM 2SS Vert Join Date: Mar 2014
I think they look great, barely noticeable...but then again I have those "black hole" wheels.
12-24-2016, 09:32 PM | #65 |
Drives: 2017 ZL1 Join Date: Oct 2016
I'm digging up an old thread, but thought I'd offer some advice bullets on the install. I just put mine on yesterday (no pics, sorry. Its hard to photograph them on black, but I do like the look of them. Mine sit flush/tight).
-You do not need to take the wheels off to install them. For the front where you need the most room, crank the wheels to one side for more access for the riveter. For the rears, I used a right angle adapter for my drill, but you could get right angle star drive wrenches. This is the best $15 tool!! http://www.homedepot.com/p/DEWALT-Ri...RA50/203867866 -Alight the mounting plate for the fronts right against the outer edge of the fender. I was worried it would not snug the guards close enough (they do not naturally sit flush), but it all snugged up when tightening things. -predrill holes in the carpet for the rivets - its too thick to easily push them through. -Use a tiny hose removal tool to help pull the carpet forward while you install the rivet. I had to do this or the rivet wouldn't have snuck behind the carpet. (Mine is like this http://ricksfreeautorepairadvice.com...moval-tool.jpg ) -This may be obvious, but use alcohol on the car to prep it and dont peel off the VHB tape liner until the screws are in place (front and rear). Its near impossible to get them to seat all the way if the vhb tape is exposed. -The rears are a bit easier than the fronts - just bolt on with no fender liner pull back needed. Note that the kit has smaller head screws for the rear which makes them seat better. I didn't realize this at first because they were stuck under the box flap and had a hard time getting the top ones to start on the threads! -I heard they will need to be trimmed if you plan to use side skirts, but it is doable. I hope someone comes out with a side skirt kit that works with the splash guards. -Install time should be about 1hr for a first timer taking their time. |
12-24-2016, 09:46 PM | #66 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
was easier to have the dealer install them pre-delivery
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
12-25-2016, 05:45 PM | #67 |
Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
I have them on my car installed by the dealer as LPO option. They are great IMHO. Discrete and do protect. Very happy I got them.
12-25-2016, 10:00 PM | #68 |
Drives: 2016/SS Has had 4 Gen 5's Join Date: Dec 2015
For me I'd go with the color matching Just my 2cents. I ordered the black rims with the red strip. They were out of stock Constraints so I took the stock OEM's. I then found the Foose's wheels and I'm really happy how they look. The center cover matches the Camaro emblem perfectly. I have been asked it's a foose edition..
[IMG][/IMG]
SnoWhite |
08-19-2018, 01:05 PM | #69 |
I am planning to install the splash guards. But hesitating on black or hot red. Anyone put black on Hot red?
08-19-2018, 02:06 PM | #70 |
Do they also work well for the 1LE?
