02-11-2021, 09:46 AM | #575 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-15-2021, 01:48 PM | #576 |
Drives: 2010 2SS & 2013 ZL1 Vert Join Date: Mar 2015
Awesome thread Ted, SUBSCRIBED!
What the hell took me so long..... |
02-19-2021, 10:03 AM | #577 |
Drives: G8 GT Join Date: Mar 2017
Earlier in this thread I lamented not being able to reliably use 15 deg timing with 15 psi boost in my twin turbo L99 Camaro. On 93 octane it will randomly show knock retard even though I'm pumping the proper amount of methanol and I thought the methanol would allow me the timing latitude that E85 supports. So my question number 1 is whether or not that is true.
Now I have read that the LS3 style intake manifold will display uneven distribution when spraying meth and on the chance that this is what is causing my random knock I'd like to convert it to direct port style injection as a possible solution. So question number 2 is have you seen benefit from direct port injection as opposed to pre-throttle style on this intake ? It seems like an interesting project even if it only nets me 2 or 3 degrees. Many thanks for your insight of course. Great information. |
02-19-2021, 11:19 AM | #578 | |
You would be much better off with E-85 then Methanol injection. I am not a fan of supplying an engine with fuel via a fertilizer pump. Ted.
www.jannettyracing.com
02-19-2021, 02:55 PM | #579 |
The main reason I've avoided the E85 conversion is the serious loss of fuel mileage and the extra distance to the E85 pumps. I know I'd enjoy the performance though.
Thanks |
02-19-2021, 04:33 PM | #580 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-19-2021, 04:46 PM | #581 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
Add a flex fuel sensor and a boost controller. Turn the boost up when on E85 the turn it down when on pump gas, or have the flex fuel tune adjust your spark accordingly.
"J.Sick"
2010 Camaro 2SS |
02-19-2021, 06:21 PM | #582 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
But i dont have twin turbos and to each his own.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-19-2021, 06:36 PM | #583 |
I've looked and searched, and asked, and asked at what temp should timing start to be pulled. Probably asked all the wrong folks but ended up "considering" anything under 200*F non-detrimental to making power with the fear of pre-ignition detonation or whatever the it's-bad phrase. What have you been told?
02-19-2021, 07:21 PM | #584 | |
Anyway, if the port injection allows me some decent timing then I'll probably just "go with it" as they say. Thanks for your input. |
02-19-2021, 07:29 PM | #585 |
If I decide to go with the "E" conversion then no doubt I'll do it all. Who doesn't enjoy tuning an E85 conversion.
02-22-2021, 06:34 AM | #586 | |
With the centri blowers I've run, I have never seen over 137 degrees on a 93 degree day doing back to back runs. Normally I'm well below 120. I'm not a tuner, just speaking from limited experience. Maybe Ted will elaborate.
02-22-2021, 02:41 PM | #587 |
Hey Ted,
I just picked up a used Huron TT kit from another user here, and I am planning on adding new FIC 1000cc injectors, a ZL1 FPCM, and possibly e85. I'm shooting for ~600whp, would those parts get me there? If not what would you recommend to get me to that power level. Thanks |
02-22-2021, 02:42 PM | #588 | |
