Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 05-22-2012, 09:59 AM   #29
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Originally Posted by BMR Sales View Post
Thanks for all the updates guys, keep them coming! We hope to have some updated 60ft times soon for our shop car.
You know, I was thinking... you could always have a different category for shop cars...
Just saying.
(Not that me being bumped up to #1 in Drag Radials has ANYTHING to do with it. )
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-22-2012, 10:07 AM   #30
Camaro21
Drives: SOLD - 2013 M6 ZL1
60 ft/time: 1.683
Tire Brand/Type: Hoosier Slicks & M&H Front Skinnies
Tire Size: 28X10X17
Suspension Upgrades: BMR Rear Adjustable Lower Control Arms, BMR Rear Toe Rods, Pedders Xa Coilovers, Pfadt Solid Rear Subframe Mounts, Eibach Front and Rear Sway Bars
Drivetrain Upgrades: DSS 9" Rear Kit, LPE MAX-CX Twin Disk Clutch
Automatic or Manual transmission: Manual
Rear Gear Ratio: 3.70
Camaro21 is offline   Reply With Quote
Old 05-23-2012, 12:34 PM   #31
FNBADAZ06
FNBADAZ06's Avatar
Drives: C6 Z06 Corvette
I'm very suprised that the majority of you use 18" wheels and such large drag radials.
Do you guys have any concerns over weight (rotating mass) and over-tiring the car ?
Still, really nice 60' times being posted.
FNBADAZ06 is offline   Reply With Quote
Old 05-23-2012, 12:51 PM   #32
Padre
Padre's Avatar
Only one guy I know of went with 26" tires, and he hasn't seemed to see much improvement. 20" rims are definitely slower.
I saved 12lbs per corner with my 18" setup, and it's got great sidewall for my application.
Padre
Old 05-23-2012, 01:36 PM   #33
FNBADAZ06
FNBADAZ06's Avatar
Padre
Just curious....have you tried a 17" wheel/drag radial setup ?
The 26" tire setup will shorten up the rear gear a bit, so as long as you hook I can't see where that wouldn't help the 60' a bit, correct ?
17" drag radials can weight 5+ pounds less than 18 or larger tires.
While the weight transfer/bias is different from a Camaro to a Corvette, along with the power delivery , I would think the same general principles apply......Limit rotational weight to maximize acceleration.
Old 05-23-2012, 05:08 PM   #34
Padre
Padre's Avatar
I did run 26" 17's with 275 MT's for years on my GTO and cut 1.500 all-motor.
With the SS, 26" tires would have me shifting into 5th gear at the traps. I have an A6 with 3.45 gears from an M6 Camaro - stock A6's have 3.27 gears.
The gearing advantage you may gain with smaller tires are more than made up for by the 6L80E's 4.03/2.36/1.53/1.15/0.85/0.67 gears.
In my opinion, the 4.03 is great for tall tires, which allow you to keep the top end performance.
As I said, we have one member here who has 26" tires, specifically for that reason. It's an interesting theory, but we haven't seen any definitive results.
Also, it's harder to find lightweight, inexpensive 17's that fit without modifying the brakes. 18" TSW's are the wheel of choice because they are meet all three requirements: lightweight, cheap, fit without modification. And my 1.535 tells the only story that matters to me.
IOW, I don't want to be shelling out $3k for wheels alone.
Padre
Old 05-23-2012, 05:36 PM   #35
FNBADAZ06
FNBADAZ06's Avatar
Padre
Ah...gotcha. didn't realize you had different rear gear already and the short 4.03 1st gear. I wonder if C5 Z06 Corvette wheels would fit on the back.....17x9.5 front's to be exact. Inexpensive and as light as they come.
Old 05-27-2012, 09:43 AM   #36
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
Category: Street Tires
60 ft/time:
1.908
Tire Brand/Type: Pirelli P-Zeros (Stock)
Tire Size: 275/40/ZR20 (Stock)
Suspension Upgrades: Eibach Springs and Sway bars
Drivetrain Upgrades: SLP Wheels, otherwise Stock from Convertor back
Automatic or Manual transmission: Automatic (Stock)
Rear Gear Ratio: 3.27 (Stock)
Southern Comfort is offline   Reply With Quote
Old 06-06-2012, 09:44 AM   #37
HDRS
Fastest V6
HDRS's Avatar
Drives: 2010 CGM 2LT/RS 06 G6 GTP conv.
60 ft/time: 1.616
Tire Size: 28x10x17
Suspension Upgrades: STOCK
Drivetrain Upgrades: STOCK
Automatic or Manual transmission: STOCK Auto
Rear Gear Ratio: STOCK
1/4 Mile 11.841 at 113.98mph
SEPA5 /TEAM LLT
HDRS is offline   Reply With Quote
Old 06-06-2012, 11:21 AM   #38
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
60ft. with Street tires
Here is my run from last fall with street tires
60 ft/time: 1.720
Tire Brand/Type: Continental ExtremeContact DWS (cheaper than stock)
Tire Size: 315/35/20
Automatic or Manual transmission: A6 6l80e
Rear Gear Ratio: STOCK 3.27
MudderFinger is offline   Reply With Quote
Old 06-06-2012, 11:32 AM   #39
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I went 1.94, all stock, A6 trans, stock Pirellis:
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 06-09-2012, 10:20 AM   #40
HDRS
Fastest V6
HDRS's Avatar
If the list works the way I think it does then I should be #3 not #4. Sorry I don't want to come off as a jerk but it's just a lil V6 and all the big boys with all the mods I'm sure will knock me off the list.
SEPA5 /TEAM LLT
Old 06-09-2012, 10:45 AM   #41
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
60 ft/time: 1.923
Tire Brand/Type:
Stock Pirelli P Zero
Tire Size: 275x40-20
Suspension Upgrades: none
Drivetrain Upgrades: none
Automatic or Manual transmission: Automatic A6
Rear Gear Ratio: 3:27 stock
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 06-09-2012, 02:46 PM   #42
Southern Comfort
Agreed. Credit where credit's due!
