09-19-2020, 06:47 PM | #1 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
1LE Front Grill Question
First post!
I read on Wildhammer that in order to use the 1LE splitter, the 1LE lower grill is required. Does anyone know if the 1LE splitter is required to use the 1LE lower grill, meaning can I just use the stock splitter with the 1LE lower grill? Thanks in advance. My 2021 ZL1 arrives in 2-3 days. I got big plans for it. |
09-19-2020, 07:25 PM | #2 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
1le grille required for 1le splitter
09-19-2020, 07:35 PM | #3 |
09-19-2020, 08:33 PM | #4 |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
Yes. You can run the 1LE upper and / or lower grille(s) with the ZL1 (non-1LE) splitter. There will be a very small gap at the grille and splitter interface. Sort of hard to explain, but it's not overly noticeable. I personally don't run this setup, but have seen a few others who do.
09-19-2020, 08:40 PM | #5 | |
09-19-2020, 09:03 PM | #6 |
Whoops my bad, reading comprehension isn't my thing apparently.
09-19-2020, 09:26 PM | #7 |
09-25-2020, 10:54 AM | #8 |
So I made the attempt to swap these pieces myself a few days ago and gave up. If anyone has tried this and been successful, I would like to hear from you. I pulled the front fascia off, and for the life of me I could NOT get the clips to release the upper grill. The lower grill looks like I'll have to break the bumper cover rivets just to pull the grill off and even then, I couldn't get those clips to budge either. I didn't want to damage the fascia I put it all back together. That was a waste of 3 hours.
09-25-2020, 11:21 AM | #9 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
The upper grill is a big PITA, but the lower grill is fairly straight forward. It is much easier with two pair of hands and/or interior trim tools.
09-25-2020, 12:31 PM | #10 | |
Drives: 2020 Camaro ZL1 1LE Join Date: Mar 2020
Anderson Composites Makes Both for that car and the quality of the carbon is insane. I pick up my 21 on Tuesday! It's already at the dealer. I am having them do the track alignment on it before I pick it up. (It's a 1LE) |
09-25-2020, 08:56 PM | #11 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
Z OH 6......here ya go.......
https://www.camaro6.com/forums/showthread.php?t=512449 11 pages.....or work backwards......lot of meat & potatoes on the backside of that thread.... Here's another.... https://www.camaro6.com/forums/showthread.php?t=512449 BTDT......have fun! |
09-27-2020, 02:20 PM | #12 | |
09-29-2020, 11:49 AM | #13 |
Drives: Chevrolet Camaro ZL1 Join Date: Nov 2019
I did the conversion, and yes, you need it. The bic below shows how the stock ZL1 grill doesn't clear all the 1L1 tabs and will not lock in properly. You would have extensive cutting and fitting, and the center of the splitter would have nothing securing it.
Also the grilles and bezels are a PITA to remove. I went tobthe auto store and bought a stack of feeler gauges. I slid the feelers between the tabs as I worked my way around the bumper. It's the only way to keep the tabs you released from snapping back when you go onto the next one. |
09-29-2020, 05:48 PM | #14 |
I've got a local body shop going to do the conversion for me in a few days. I'm going to paint the 1LE splitter mosaic black like the stock one. Leaving the grills unpainted.
