10-22-2020, 11:25 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Feb 2016
Valentine V1 Gen2 - Hardwire Install w Concealed Display
Check it out!! Hope it helps everyone!!
https://youtu.be/TcvY6szBX1Q Install w Coax RG6 center conductor for dsub pins for purple white and black wires from white plug in ceiling https://youtu.be/soZ-58dg_AU Final Result |
10-23-2020, 08:03 AM | #2 |
Drives: Turbo 6.2 Join Date: Feb 2019
nice video. whats the point of the 2nd display? Does it mimic the original display on the box?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
10-23-2020, 08:51 AM | #3 | |
You can set the settings to have the radar detector up by the mirror go black when the concealed display is installed, or have them both light up. |
10-23-2020, 09:16 PM | #4 |
Drives: 2018 2ss redline Join Date: Sep 2019
i did that wire before. when you spin tires & the traction control light comes on, the power will be cut from purple/white for maybe half a second. for my uniden, that was long enough to turn it off. then i'd have to pull the power cord to restart it. if your valentine can hang on, it may work for you.
11-04-2020, 01:22 AM | #5 | |
