12-14-2018, 09:08 PM | #15 | |
I’ll re-state, I like the fuse pulled sound all the time, I don’t like two tips dirty and two clean, looks stupid from a purist POV. And to be honest, I’m not a fan of thick double walled tips at all, I’d prefer single wall like real race cars, that I believe would do justice to the tail pipe esthetic IMO. If I can’t find a system that fits my criteria, I may modify the tips on the OEM system as described above if I have the guts todo it ! |
12-14-2018, 09:31 PM | #16 | |
When you remove the factory cat back, you have to snip the OEM clamp on the drivers side where the secondary cat connects to the primary cat. You'll have to order an OEM clamp if you were to ever re-install the OEM setup. I am not sure how well it would work thought, haven't gotten to that point. I did the full Corsa cat-back for the same reasons, didn't want to cut. But to put it back to stock, I think I'd have to order an OEM clamp and possibly tac weld a piece of it or maybe be able to reuse the factory one. Again, haven't gotten to that point. Last edited by Can'tHave2MuchHP; 12-14-2018 at 09:41 PM. |
12-14-2018, 09:37 PM | #17 |
Hopefully this helps...Just a crude pic/edit I did real quick to help demonstrate.
12-14-2018, 09:43 PM | #18 | |
12-14-2018, 09:59 PM | #19 | |
No effect to the tune, no check engine light. Should be worth some power and it definitely will add some volume. I did both my C7 Z06 and 2018 ZL1 with full cat-backs (secondary cat deleting X Pipes on both) and I can't remember if the ZL1's secondary cats are hollow or packed. They should be called resonators. By the way, if you are taking it to a shop for install, they're definitely called resonators, wink wink. |
12-14-2018, 10:00 PM | #20 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Thank you for the pic, that’s what i was trying to let him know...he could have the secondary cat, or not cut...one of the two, but not both.
I know it’s a cheaper brand, but the MBRP sport meets most your requirements OP...i cannot speak to the quality, but I’m considering trying it if they keep the price down($493 on amazon). You would have to cut, but some clamps or welding by any shop should return it to stock easily. I installed a resonator delete on my last car with a sawzall and a dremel(I’m not a mechanic) and it was a fun project, and then i was a little more familiar with the car. Plan on doing the same with this one, I’m sure you could if you wanted to |
12-14-2018, 10:13 PM | #21 | |
12-14-2018, 10:16 PM | #22 | |
I’ve got a shop, I weld and machine things for work and myself so I’m covered in the fabrication dept ! |
12-14-2018, 10:21 PM | #23 |
Lol yeahhh I’m a little scared...it’ll either fall apart and lessons will be learned, or it’ll last forever and make me feel as if i actually saved a little cash. After fitting up corsa and stainless works in the past(they were great), I’ll at least have something to compare it to quality/fitment wise
12-14-2018, 10:25 PM | #24 |
BlaqWhole has an MBRP race exhaust on his ZL1 - may want to PM him.
https://www.camaro6.com/forums/member.php?u=61072 |
12-14-2018, 10:42 PM | #25 | |
I looked on their site, I don’t think they’re stainless, couldnt find that level of information, didn’t look real hard either ! If so that will account for much of the cost difference. I also bet they’re pretty loud, not much there to muffle the exhaust note. |
12-14-2018, 11:34 PM | #26 | |
https://www.amazon.com/dp/B01MUT02UQ...ing=UTF8&psc=1 |
12-15-2018, 12:18 AM | #27 | |
Drives: 2017 ZL1 Join Date: Jun 2012
12-15-2018, 09:07 AM | #28 | |
Drives: 2019 ZL1 A10 Black Mosaic Join Date: Nov 2018
