05-07-2019, 04:02 AM | #1 |
Drives: Camaro ZL1 2017 Join Date: May 2019
ZL1 reduced power 50% low
hey guys
would you please help me out i owned so many sport cars and recently sold my camaro SS and bought "17 ZL1 my ZL1 is under warranty and no any modification at all completely stock suddenly the car reduced power 50% low. i got it over a professional-dynojet n town. it got 398 WHP / 448 TQ i took to my dealership technician said there's no code showing he also refused to test my car i can not understand the problem of reducing power please get me some information 🚫🚫🚫🚫🚫🚫 |
05-07-2019, 04:14 AM | #2 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Go over your owners manuals. Make sure the vehicle isn’t in a mode where power is reduced for valet services, and or teen/young driver.
It sounds to me like this is the case. This would also explain why there is no engine light also. |
05-07-2019, 04:24 AM | #3 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Sounds like the teen driver key is being activated.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
05-07-2019, 06:25 AM | #4 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
Possible air in the intercooler system which causes the pump to cavitate and shut off. IAT will then climb and the engine will retard timing. No codes or check engine light will occur when this happens.
05-07-2019, 07:15 AM | #5 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
Teen driver mode seems like the culprit, I don't think valet does limp-like mode.
If I were a parent giving this car to my kid, I would likely do the same - except for track days. |
05-07-2019, 08:17 AM | #6 |
i just use my second key and checked PDR it's already in safety mode
but my basic key already not giving the full power |
05-07-2019, 08:43 AM | #7 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Those numbers seem to high for "Teen Mode", don't they? Teens and valet drivers can still have a lot of fun with 448 lb ft of torque at the wheels. That is more than my C7.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
05-07-2019, 10:11 AM | #8 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Needs to be hooked up to a scan device to see if anything's out of spec. You could try disconnecting the battery for a while and see if the problem goes away temporarily.
05-07-2019, 12:05 PM | #9 | |
Drives: 2019 ZL1 A10 Join Date: Jan 2019
05-07-2019, 12:18 PM | #10 |
@viurniel
I agree with Fatty1707 above
05-07-2019, 12:31 PM | #11 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
From everything I've read, valet and teen mode do not reduce power. Would be cool if they did.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
05-07-2019, 12:35 PM | #12 |
Drives: gas powered Join Date: Jan 2019
I would guess it bad fuel.
I think in his country they have varied fuel requirements and they dont rate there fuel like we do. |
05-07-2019, 12:55 PM | #13 |
@viurniel
Can confirm that valet and teen mode do not affect HP/TQ.
05-07-2019, 12:55 PM | #14 |
Drives: 2018 ZL1 Join Date: Mar 2019
Had a similar issue, which was found to be a faulty Mass Air Flow Sensor Wire. Quick simple fix. Not sure if there were any fault codes thrown or not, but had the same message that you are receiving.
***2018 ZL1, CALLAWAY SC750, NFG, 6 Speed, Carbon Fiber Hood Insert, PDR, Carbon Fiber Dash, Tony Mamo V2 TB, Borla S-Type Cat Back Exhaust (Carbon Tips), Hurst Short Shifter, Eibach Performance Springs, IROC Blade Spoiler, GM Dark Lens Kit/Reflectors, Diode Dynamics Smoked LED Side Markers, Wildhammer Carbon Steering Wheel, CF Shift Knob, Titanium Lug Nuts***
