10-18-2020, 01:15 PM | #15 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
Color also doesn’t match. Not sure how they messed up this bad
10-18-2020, 01:49 PM | #16 |
Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
Wow...that's some incredibly lazy and shitty work.
10-18-2020, 02:12 PM | #17 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Unfortunately it's extremely hard to find good body and paint operations these days.
10-18-2020, 02:32 PM | #18 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
10-18-2020, 04:23 PM | #19 |
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
10-18-2020, 05:41 PM | #20 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Only the base coat is water base, all clearcoats are chemical base and are a chemical dry product not a air dry product. If someone touched the finish before 8 hours of drying time at 70 degrees , you can leave a finger print. If the bumper cover was cured in a properly heated to cure urethane paint booth, than it should be fine to touch when removed from the booth. Let the car sit in the hot sun a view days and have the shop 2000 grit sand paper and polish out the finger print.
10-18-2020, 07:01 PM | #21 |
Drives: 2015 Camaro Join Date: Aug 2018
10-19-2020, 06:45 AM | #22 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
That a big no no to me. They should redo it completely.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
10-19-2020, 08:05 AM | #23 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
10-19-2020, 11:32 AM | #24 |
Took it back, calmly explained to the guy what the issues were. He said they would take it back and polish it and try to get the color to match. I have a hard time believing they are going to make it 100% right. If it comes out wrong I may just have to find a legitimate paint shop to do it
10-19-2020, 11:49 AM | #25 |
10-19-2020, 12:33 PM | #26 |
Drives: 18 2SS 1LE, 20 Canyon Denali Join Date: Feb 2016
polishing will clean up the swirls, but wont do anything for the color match issue
Mike
Current Garage: 18' 2SS 1LE, Hyper Blue 23' GMC Canyon Denali Previously: 20' GMC Canyon Denali 16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss) 14' Ford Edge Sport 06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada |
10-19-2020, 01:16 PM | #27 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
It is very difficult to find a body shop that does high quality work. Getting the paint to be close in color, is another struggle on top of that. Those are two reasons I avoid having any body work done unless it is necessary...obviously in your case, it was.
I'm not sure what you have for paint, but some paints are not going to match - plain and simple. For example, I would argue that it is physically IMPOSSIBLE for a human hand to replicate a tricoat paint that is factory sprayed by a machine. Getting the paint to match and blending the panels are two different things. A good shop will blend the paint if it needed. |
10-20-2020, 09:31 AM | #28 |
Drives: 2004 Honda Civic+2011 Camaro 2SS Join Date: Sep 2013
just had to get a new bumper for my buick with tricoat paint. Match was spot on, at least as close as you will get for a bumper compared to a metal/aluminum body panel.
Paint adheres to a bumper diff so will look slightly different but a good painter can make it look like factory. No need to blend because again, the bumper and panel are diff material |
