Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 08-30-2023, 11:06 AM   #1
Dirtmod66
Dirtmod66's Avatar
Drives: 2010 Camaro SS
Surge when slowing down at a light?
415 build, Holley Hi-Ram, 103mm tb, 12:7.1 engine gapped for nitrous. Custom Cam with wide LSA for 6500 Altitude and 8500+DA. Car has excellent hp & torque, 3800 stall.
Car surges (between 1200-800)when slowing down to come to a stop and brakes are slightly harder: question is would a vacuum canister help with this problem?
Dirtmod66 is offline   Reply With Quote
Old 09-02-2023, 10:11 AM   #2
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
idle
typically, a wider Lsa Idle vacuum is increased, along with idle quality improvements.
As a tighter lsa vacum is reduced and idle quality suffers.
Check for any type vacuum leak, or maybe a slight tune adjustment down low on decell, from fueling, a lot of times I see timing being the cause, or in torque management. But with a wider LSA you should have good vacuum.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
