Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-30-2013, 10:19 AM   #43
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Sooooo for a full cleaning we spray into that little hole near the throttle body, the brake booster, put some in the gas tank, and some in the oil? Then change the oil right after or X miles later?
How much do we use too? One can? Helppppp lmao
DarkneSS is offline   Reply With Quote
Old 03-30-2013, 10:37 AM   #44
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
You need 2 cans of the liquid and 1 can of the spray. 1 full can of the liquid in the gas tank. 1/2 a can of the liquid in the oil other half in the booster hose. Spray the TB and change oil after about 100 miles. At the beginning of this thread there's a DIY link. I will be making one for the LLT when I get a break from the rain. I may do a photo DIY first and the video later.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 03-30-2013, 10:49 AM   #45
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I also just thought about something. If you were to spray the Seafoam through the TB. (by opening the tb blade with your hand) With the car off of course you can get a even spray across the IM. Resulting in skipping the booster hose step. And it will drain onto everything and sit like the booster step would for a few min. But this is in theory. For those not confident to do the booster hose part. This is a THEORY. Plus remember the engine must be warm. Or just wait for the DIY.
Old 03-30-2013, 11:01 AM   #46
DarkneSS
Thanks so much for the help so far man I and I'm sure everyone else really appreciate it. Its definitely a good theory, who knows...
I've got another 1,000 miles until I need an oil change so I'm going to hold tight for your DIY. I need a catch can too and it seems counter productive to seafoam without a catch can. So I'll order that and install it the same day I seafoam and do an oil change. Should be a fun day!
Old 03-30-2013, 11:30 AM   #47
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I'm waiting. Thanks for taking the time to help us noobs out.
[B]
CamaroDreams07 is offline   Reply With Quote
Old 03-30-2013, 12:36 PM   #48
Chaotic73
BUMBLLB
Chaotic73's Avatar
Drives: 2010 Camaro 1LT/RS
Can you get away with just using the Seafoam spray and put directly into the IM or do you need to put it directly in the gas and oil as well?
Chaotic73 is offline   Reply With Quote
Old 03-30-2013, 01:33 PM   #49
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Yes you can, I do it every oil change. Just don't expect a huge change cleaning wise.
Old 03-30-2013, 04:02 PM   #50
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Keep seeing that the brake booster only gets half the engine. I'm liking the throttle body spray as this should get the whole engine.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 03-30-2013, 04:59 PM   #51
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
As someone that did it from the front, it gets only the front four cylinders. I think you need to get it from both ends. Hmmm... That didn't come out sounding right.
PieNsky is offline   Reply With Quote
Old 03-30-2013, 05:14 PM   #52
SC2150
Drives: 2012 Camaro RS, RX supercharged
LOL Pie!!!
SC2150 is offline   Reply With Quote
Old 03-30-2013, 05:19 PM   #53
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
This is correct the TB only gets the front cleaned. For the rear to be properly cleaned you'll need the booster line.
I have all the pictures for the write up. Not many needed. Got ambushed into spring cleaning by my wife so I'm being held hostage. Will write it by end of weekend.
Old 03-30-2013, 05:38 PM   #54
RubyCamaro
Jan
RubyCamaro's Avatar
Old 03-31-2013, 09:01 AM   #55
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
LLT Seafoam DIY posted.
http://www.camaro5.com/forums/showth...=1#post6362311
Old 04-01-2013, 10:03 AM   #56
SC2150
Nut is correct. Any intake manifold introduction while running will distribute pretty evenly.
