05-15-2018, 11:40 AM | #141 |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
Yeah man. I put the CF trim in the ZL1 already.... so I'll put the ZL1 Suede dash trim in this when I get it in.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
05-15-2018, 01:30 PM | #142 | |
Sarcasm loading --------
The SD reader that i got last week had a female plug on it.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-15-2018, 02:43 PM | #143 |
PDR Component part numbers and install
Based on that image it looks to me anyway that the PDF shows the SD Reader as the male plug see below (my connector will be in tomorrow so I’ll post a pic of what I received Here is what they are showing as the female plug Sent from my iPhone using Tapatalk Pro
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar Last edited by mbnwa; 05-15-2018 at 03:08 PM. |
05-15-2018, 05:52 PM | #144 |
I hope youre right so I can return this one and save a bunch of money for a stupid connector.
05-16-2018, 12:16 PM | #145 | |
I can confirm this does fit the SD Card reader Sent from my iPhone using Tapatalk Pro
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar |
05-17-2018, 02:44 PM | #146 |
Now to do some tracing
PRIOR CAR:
05-17-2018, 02:48 PM | #147 |
05-17-2018, 06:47 PM | #148 |
I ordered a bunch of connectors last night at 5:30pm; the box was packed, shipped and delivered today!
05-17-2018, 08:12 PM | #149 | |
The USB cables are intact tied into the harness (excluding the one going to the camera, the cable runs to the A Pillar and it looks like another cable connects at that point to go to the camera) and wrapped tight, does not look like any part numbers are listed on the cables when I get everything broken down I plan to measure each cable to get length that is used. Last edited by mbnwa; 05-17-2018 at 11:22 PM. |
05-17-2018, 09:18 PM | #150 |
Drives: 2016 Vert 2SS/2018 ZL1 Vert Red Hot Join Date: Dec 2016
LOL, you bought that dash piece from me .
05-17-2018, 09:34 PM | #151 |
The connections for this harness is based on the ZL1 harness that I received and the two attached documents, please note all my testing / tone mapping was done from the wire harness connectors I.E the connectors that would plug into the PDR short connectors.
EDIT: CONFIRMED WORKING ON 5/24/2018 PDR X3 PDR Blue Plug == 2nd USB of Display Grey USB plug X4 PDR Black Plug == Camara (dash harness does not have the complete cable it's missing a section) X5 PDR Green Plug == SD Card Reader / Writer Grey USB Plug (Driver side dash) X202 & X203 connections are based on the pins from the dash side connectors of the short PDR cable image below: X203 - (Short Grey connection from PDR - !!DASH CONNECTION SIDE!! OEM Connector: 13503526) X203 NON-PDR SIDE Pin 1 - not used X203 NON-PDR SIDE Pin 2 - not used X203 NON-PDR SIDE Pin 3 - not used X203 NON-PDR SIDE Pin 4 - not used X203 NON-PDR SIDE Pin 5 - not used X203 NON-PDR SIDE Pin 6 - GN/YE - Remote Enable Signal - Circuit #7066 - Goes to Radio A11 X1 P2 X203 NON-PDR SIDE Pin 7 - BK - Auxillary audio screen 2 - Circuit #5842 - not used on our cars it seems. X203 NON-PDR SIDE Pin 8 - GN - Right Auxillary Audio 2 - Circuit #5841 - Goes to Radio A11 X1 P10 X203 NON-PDR SIDE Pin 9 - GY - Left Auxillary Audio 2 - Circuit #5839 - Goes to Radio A11 X1 P9 X203 NON-PDR SIDE Pin 10 - VT - Auxillary Audio Common Signal - Circuit #5843 - Goes to Radio A11 X1 P8 X203 NON-PDR SIDE Pin 11 - BN/GN - Video Display Request Signal - Circuit #4502 - Goes to Radio A11 X1 P16 X203 NON-PDR SIDE Pin 12 - BU/VT - Audio Request Signal - Circuit #4609 - Goes to Radio A11 X1 P17 X202 - (Short Black connection from PDR - Dash Extension !!DASH CONNECTION SIDE!! OEM Connector: 13503527) X202 NON-PDR SIDE Pin 1 - RD/GN - Battery Positive - Circuit #3140 - Goes to fuse block X53A X1 P9 in trunk well, Fuse F51RA - 10 amp, check for fuse and power. (however mine is connected to the HMI power feed to keep all connections in the passenger footwell) X202 NON-PDR SIDE Pin 2 - GYGN - Low Speed GMLAN Serial Data #2 - Module K73 X1 Pin 1 X202 NON-PDR SIDE Pin 3 - WH/BU - Serial Data Communication Enable - Circuit #5986 - Goes to Pin 5 on HMI X1 Black connector X202 NON-PDR SIDE Pin 4 - BU/GN 2500 (J208) - High Speed GMLAN Serial Data (+)9 (Pin 13 on HMI X1 Black connector) X202 NON-PDR SIDE Pin 5 - WH/GN 2501 (J209) - High Speed GMLAN Serial Data (-)9 (Pin 14 on HMI X1 Black connector) X202 NON-PDR SIDE Pin 6 - not used X202 NON-PDR SIDE Pin 7 - not used X202 NON-PDR SIDE Pin 8 - GN/WH 7527 (J216) - Local Interconnect Network Serial Data Bus 5 (Pin 9 on HMI X1 Black connector) X202 NON-PDR SIDE Pin 9 - not used X202 NON-PDR SIDE Pin 10 - not used X202 NON-PDR SIDE Pin 11 - not used X202 NON-PDR SIDE Pin 12 - BK/WH 1551 (J204) - Signal Ground Pin 8 on HMI X1 Black connector SD Card Reader (X20 X2) Pin 4 Ground Pin 6 Battery + RD/GN - Battery Positive - Circuit #3140 - Goes to fuse block X53A X1 P9 in trunk well, Fuse F51RA - 10 amp, check for fuse and power. (however mine is connected to the HMI power feed to keep all connections in the passenger footwell)
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar Last edited by mbnwa; 06-03-2018 at 05:31 PM. |
05-17-2018, 09:36 PM | #152 |
so you bought the whole harness from the car that equipped with PDR?
05-17-2018, 09:38 PM | #153 |
05-18-2018, 07:43 PM | #154 |
Did all the wires from the gray connector on the PDR go to the radio connector a 11?
