05-03-2021, 11:09 PM | #1 |
Drives: 2018 2SS 1LE Join Date: Feb 2021
DSX aux fuel pump enough for a Procharger
I have a 18 1LE M6, already full bolt on, with texas speed stage 2 cam, 520 whp, on 93
Im wanting to get the Procharger base kit, 7 psi, but am curious about the fuel system. Since I already have the LT4 in-tank pump, would adding the DSX aux pump be enough? Or would I have to get LT4 high side and injectors? I will stay on 93 only, not running E. |
05-04-2021, 06:39 AM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
I would just do the high side and see where you're at since you plan on staying on 93.
05-04-2021, 06:49 AM | #3 |
BAMF SS
don't need the aux pump
definitely get the lt4 injectors and lt4 high side pump though.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
05-04-2021, 08:40 AM | #4 |
I would get the LT4 high side stuff and put a JMS on the low side. I believe there is a JMS for sale either here or on FB.
2016 NFG 1SS A8
