Old 12-15-2021, 11:37 AM   #15
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Just talk to Ted on the best route to go. I have worked with him on and off for years and that man has plethora of knowledge.
If I was you I would buy your own MPVi2 from him and learn how to change your tunes through HP tuners. Very simple. Have him do a 93 and then what ever race fuel you guys agree on.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 12-15-2021, 12:29 PM   #16
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by MartinLe View Post
I was under the impression, that was my set up, I would not be able to run any ethanol.
If you have a similar build like myself or ineedaz you should be able to run e40-e40. I don’t think though the low side booster is going to cut it. You should get a real low side aux pump. I have a 400lph Holley, but the dsx should be fine too just less flow.
I run e40 and it’s about 35+rwhp. Somewhere around 23 degrees total timing.
E40 should be about 98 octane.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 12-15-2021, 03:24 PM   #17
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
What Holley system did you use?
What do you think about the Cordes setup?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 12-15-2021, 08:00 PM   #18
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I have a holly 12-170 pump w/check valve. The cordes system looks ok, looks pretty much like the dsx system which uses a walbro pump.
Old 12-16-2021, 09:46 AM   #19
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
My car on Meth & E40, 18psi
Injector pulse width was 6.3-6.5
Cam 32% fuel lobe, DSX lowside, 103, Big gulp and Maggy 2650
'17 ZL1 M6
8xxwhp Magnuson 2650
Sickspeedkuwait is offline   Reply With Quote
Old 12-16-2021, 10:50 AM   #20
IneedAZ
IneedAZ's Avatar
Do you remember what Lambda you were at? My guess low if the PW was that high.
Old 12-16-2021, 01:59 PM   #21
Sickspeedkuwait
Drives: '17 ZL1 M6
AFR at 12.3
'17 ZL1 M6
Old 12-16-2021, 03:30 PM   #22
JANNETTYRACING
JANNETTYRACING's Avatar
Hey Guys, I am putting the car in the shop later this week for the install of Jannettys Terminator Cam / 2650 Maggie package w/ +30 FICs. I am curious to find if there is a octane sweet spot for this build like there is for E (60%) with the JRE 125 Flex Fuel build. I can get 110 race fuel by the barrel, leaded and unleaded. What do you guys think. Thanks in advance.
Thank you for your business Martin.
The thing you want to avoid is Leaded fuel.
I personally like Cam 2 GT100 unleaded, its not to high not to low it's just right LOL
The compression is too low to run very high octane fuels.
Feel free to call to discuss your goals.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-18-2021, 01:08 AM   #23
airtroop01
Drives: 2018 Cadillac CTS-V
Cordes is better than the DSX low side IMO.
The system features a Bosch 044 pump which flows better than the Walboro 255.
It also has a aeromotive fuel pressure regulator and a return line.
The return flows back to the feed which if plumbed correctly can minimize momentary fuel starvation when under high g’s.
The regulator system also minimizes any tuning issues to compensate for when the pump turns on. You can tune for it but better if you don’t have to.
I am not necessarily a fan of the electronic box they use to trigger it.
Cordes trigger is less elegant but kept it simple.
airtroop01 is offline   Reply With Quote
