06-01-2021, 02:57 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
GASOLINE ADDITIVES
Hey guys, I am about to run my monthly tank of straight 92 after running E60 all of May.
What if any additive are you adding to the gas? Thanks in advance for your help. |
06-01-2021, 02:58 PM | #2 |
I think the manual says a tank of 92 octane every oil change interval and only to add chevron techron
06-01-2021, 03:00 PM | #3 |
06-01-2021, 04:25 PM | #4 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
06-01-2021, 04:27 PM | #5 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I wouldn't add anything. Ethanol burns so clean it doesn't leave deposits so there's really no need to run any cleaner additive through the engine. I suppose there's an off chance the injectors could have a little build up but I doubt it.
06-01-2021, 04:32 PM | #6 |
Thanks I left out that important part, that’s the guidance in the manual from ecotec3 2014+ trucks with flexfuel
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 06-01-2021 at 05:48 PM. |
06-01-2021, 05:44 PM | #7 | |
There is no evidence that my injectors require any attention. She's burning strong and clean. No additives for my girl. Thanks.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
06-01-2021, 05:54 PM | #8 |
As I would expect. I wouldn't add anything. That's just another perk of running high ethanol content fuel, it's so clean.
06-01-2021, 06:16 PM | #9 |
i use the lucas one about every 3 months or so
06-01-2021, 07:09 PM | #10 |
06-01-2021, 08:10 PM | #11 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
I've started using a "splash" of Schaeffer's SoyUltra fuel additive, especially when wrapping up from track weekend, when the car tends to sit for a bit with the dry E85 in it between events.
