10-14-2020, 12:20 PM | #1 |
Drives: 2017 Camaro 1ss A8 Join Date: Nov 2019
Will a Nitto nt555 G2 fit stock wheel
Will the nitto nt555 G2 fit the stock front wheels. They come in a 255/35/20 or 265/35/20. I ordered some Nitto nt555r for the rear 305/35/20 and people on here had no issues with them on stock rear wheels. My front and rear eagle f1 are bald and now looking for a full set. Please lmk if there’s will fit the front stocks. Thank you
10-14-2020, 05:09 PM | #2 |
My opinion is the 305 is too wide for a stock wheel and taller than the stock tires. But I think thr Nittos will match each other. The the Nitto fronts will match the height of the 305 which Stabilitrac needs if you go with that tire. On my 2016 SS 265/35/20 nitto nt555 G2s required a spacer so it would not rub in the front.
Most if not all 20" DRs as far as the ones I can find are about 1" taller than the stock height front. This is right at the limit where the difference in size will affect Stabilitrac. So I went with some 17" Dragstars and a MT ET Streets at about 27" and have no stabilitrac problems. Try the tire section. 20" wheels limit your choices. Not sure why GM went with 20s. Heavy.
10-14-2020, 07:36 PM | #3 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
I should find a way to keep this link handy. Seems to be coming up a lot
https://www.camaro6.com/forums/showthread.php?t=556921 |
10-14-2020, 09:43 PM | #4 |
305/35/20 555r fits the stock wheel about perfect. It runs narrow compared to other 305 tires including the 555r2. The 555 G2 also runs narrow, so you can go up a size on those for the fronts. If you want the 555r2 drag radial then I wouldn't go larger then the 295/35/20.
2016 NFG 1SS A8
10-19-2020, 09:14 PM | #5 |
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
I have 285/30/20s and 315/30/20s Nt555 G2's on my 1LE no rubbing issues what so ever
10-20-2020, 06:32 AM | #6 |
Drives: 2018 Camaro SS Join Date: May 2019
I can't tell you how or which Nitto 555 G2 will fit but the one thing I can tell you about the G2 is if you plan on building much horsepower over what you already have you won't get the traction you want.
Just something to consider.
GPI ported LT2 intake
Kooks 1 7/8 long tubes high flow cats Mamo ported 87mm TB CAI cold air box Vellosa ram air MBRP axle back E85 Flex fuel sensor Tuned by GPI |
10-20-2020, 06:38 AM | #7 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
That said, you should be able to get away with putting 305/35's on 9.5" wheels for short-term or emergency needs. But I wouldn't ever do a combination like that as a mount 'em up and forget about 'em until they're almost bald mod. Quote:
Norm
'19 WRX 6M (the family sedan . . . seriously) |
10-20-2020, 09:26 AM | #8 | |
Here is the proof.... Both 305's https://www.camaro6.com/forums/showp...1&postcount=53
2016 NFG 1SS A8
10-20-2020, 10:52 AM | #9 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
