Roto-Fab
Old 03-03-2020, 08:29 AM   #1
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Boost Controller recommendations
I'm probably going to install a boost controller on the Huron Speed twin kit I have. For the people who have done this, did you use one solenoid or two? I think there are advantages to doing it either way, I'm just curious what has worked for other people.
FrankT is offline   Reply With Quote
Old 03-03-2020, 09:01 AM   #2
Omega
Drives: G8
I use a single solenoid GFB3 on a twin kit. No complaints here
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-03-2020, 09:47 AM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
Dido!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 03-03-2020, 10:35 AM   #4
hillshooter
Drives: 2015 Camaro SS commemorative
AEM TruBoost is common and affordable. Single port and uses a standard PWM type signal.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 03-03-2020, 12:01 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
A single solenoid may get you about 2x the wastegate spring in boost (e.g., you have an 8# spring, you may get up to 16# boost with the EBC). This is generally fine with a SBE LS3/L99 setup.
A dual solenoid may get up 3-4x the wastegate spring. You will loose precise adjustments when getting high in boost, like adjusting a few WG duty cycle point may get you a larger swing in boost.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 03-03-2020, 12:57 PM   #6
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Dual solenoid eBoost2, love it.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-03-2020, 02:01 PM   #7
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Boostleash pulse controller with built in bump feature. It also data logs each run and shows boost throughout the run.
graf101 is offline   Reply With Quote
Old 03-04-2020, 08:17 AM   #8
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
good stuff here guys. Thanks for all the different responses.
joshnmn is offline   Reply With Quote
Old 03-04-2020, 09:24 AM   #9
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I was using the built in boost controller on ms3. It's a total pos so I'm switching to the boost leash. I'm using co2 as well. Highly recommend using it
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 03-04-2020, 01:13 PM   #10
bayarea408
bayarea408's Avatar
Drives: T
Im on aem tru boost, its really simple and has a scramble option, open loop style controller.
If i could do it over again i'd get an Eboost 2, just to play with boost by gear.
bayarea408 is offline   Reply With Quote
Old 03-04-2020, 09:55 PM   #11
dreksnot
dreksnot's Avatar
I have the AEM TruBoost currently. Really like it for as simple as it is and use both boost settings A and B, plus have the Scramble hooked up. Overboost protection works well. Easy to program right on the gauge.
Recently I purchased a Cortez. It has a lot of bells and whistles including boost by gear and can control meth, nitrous, secondary fuel pumps, and/or do scramble. I haven't had time to swap out controllers just yet. Expecting it to be really groovy.
Old 03-05-2020, 07:59 AM   #12
FrankT
FrankT's Avatar
Thanks for all the responses, everyone. I appreciate the help.
Frank
Old 04-21-2020, 12:30 PM   #13
NXTLEVL
NXTLEVL's Avatar
Drives: 2010 Camaro SS/RS Twin Turbo LSX454
Hi dreksnot
I've been looking at getting a Cortez unit as well but I know very little (nothing) about boost controllers. Can you expand a little on why you decided to go with the Cortez unit? When you get around to installing in please do post. I'd love to have a walk-through of sorts from a Camaro owners pov.
NXTLEVL is offline   Reply With Quote
Old 08-01-2020, 10:14 AM   #14
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I'm installing my EBC this weekend. Where are you guys mounting the solenoid? My turbo kit is the Huron single kit.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
