12-10-2020, 08:23 AM | #1 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Coil relocation
I am interested in relocating my coils and changing my valve covers. I know there is tons of info on this site about it however most of them are old the the parts are no longer available. Has anyone recently done this? I know I will need the brackets and extended spark plug wires and I will more than likely install some heat sleeves on the plug wires while relocating them. Any recommendations on the parts for this is much appreciated.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
12-10-2020, 04:33 PM | #2 |
This might be an old thread, but maybe you can use some of the info. I saved it for my future usage.
https://www.camaro5.com/forums/showthread.php?t=476454
12-11-2020, 06:29 PM | #3 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Its really easy to do if your handy.
I made mine out of stainless steel. Tube, allthread, round bar and a little flat stock. Then I bought the parts to make the wires from Summit. This set mounts to the stock valve cover but you can mount them how you like.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
12-11-2020, 10:33 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Look into ict billet, just be sure to get the right ones
12-12-2020, 09:23 AM | #5 |
I did mine 3 years ago, moved them down to the frame rails. I bought the coil brackets and coil wire extensions from a forum member.
For the wires, I bought a roll of MSD wire & boots from Summit - Wire - https://www.summitracing.com/parts/MSD-34013 boots - https://www.summitracing.com/parts/MSD-3301 Boots - https://www.summitracing.com/parts/MSD-3304 It's a fairly easy project to do.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
12-12-2020, 11:13 AM | #6 | |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
12-13-2020, 09:39 AM | #7 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
these are cost effective and look good:
https://www.jegs.com/i/Proform/778/141-262K/10002/-1 these look better wit their coil kit...but three times the price: https://store.katechengines.com/cast...overs-p15.aspx
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
12-13-2020, 11:57 AM | #8 |
Try Motion Race Works as well. Does anyone have a source for a coil power extension??
Orange Krush II
12-14-2020, 05:48 AM | #9 |
here you go - https://www.camaro5.com/forums/showp...2&postcount=60
