08-11-2022, 03:07 PM | #1 |
Drives: 2022 Camaro 2SS 1LE Join Date: May 2022
1, 000 Mile Observation
Hey all. Well hit 1K miles on the 1LE and had some questions. I see the brake dust issue is real. I washed the car a few time since purchase but for the first time I needed to do the door jams and under trunk lid. So I have not driven the rain yet but was surprised how much dark dust there is in these areas. Is this in fact brake dust? It's not generated from road splash since I haven't even hit any puddles due to the overly dry period we are having in the North East.
08-11-2022, 03:30 PM | #2 |
I’ve noticed the same areas getting crusty whether being in the weather or not. Also radiator support, intake plumbing, engine cover, bottom side of hood, top of fenders and the plastic by the cowl.
It gets cleaned every time the car is washed and seems rather normal to me. So much so it’s part of the detailing routine.
08-11-2022, 03:32 PM | #3 |
Add some rock guards/mudflaps, that'll generally help with everything those wide tires throw backwards.
You can check for brake dust by spraying a bit of wheel cleaner on these spots (but rinse it off soon afterwards), if it turns deep purple, the dust contained iron and was probably brake dust. Apart from that, yeah, those places do get dirty on my car as well as other 6th gen Camaros I've seen, it's normal.
08-11-2022, 05:38 PM | #4 |
Drives: 2022 1SS 1LE Join Date: Nov 2021
ceramic coat your paint and your rims. I did and the brake dust doesn't build up nearly as fast and its super easy to clean them now.
2022 Shadow Gray Metallic 1SS 1LE A10 Rotofab Dry ST delete.
08-11-2022, 07:35 PM | #5 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Brake dust is a fact of life with a high performance machine. That's why the wheels are "brake dust black" instead of gloss.
08-11-2022, 10:11 PM | #6 |
I’ve never been a ceramic coat kinda guy, but decided to try it on my wheels. As you said, much easier to clean… whether it’s brake dust or just dirt in general.
08-12-2022, 07:36 AM | #7 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Powerstop Z26 if you want to knock out the brake dust if you can live with a little less aggressive pad and braking
09-07-2022, 02:34 PM | #8 |
Drives: '23 1LE, '18 Canyon, '87 325i Join Date: Jul 2022
All performance brake pads leave a lot of dust. I've used SotpTech performance on the street for so long, I just call them DustTechs.
Keep up with your clay bar regiment and occasionally you'll need to use a product like IronX. Ceramic coating will help alleviate particles imbedding themselves into the paint, but with proper care it can be dealt with. |
10-10-2022, 02:07 PM | #9 |
Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
I've applied ceramic wax on the wheels right after buying my 1LE. There is a lot of break dust, but with ceramic applied it washed away easily with a hose.
P.S. Now I understand why 1LE comes with black wheels only. Regular silver sheels will look terrible with thick coat of brake dust. |
10-10-2022, 02:17 PM | #10 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
10-12-2022, 02:44 PM | #11 |
Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
I recently installed Hawk HPS 5.0 pads and the dust is reduced quite a bit. Great on the street, and do work well for AutoX.
10-13-2022, 12:18 AM | #12 |
Drives: 2SS 1LE Join Date: Oct 2011
Yes, just don't drive your car, that will solve it.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
10-13-2022, 09:02 PM | #13 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
My wheels were ceramic coated, but that did little for minimizing brake dust or making them easier to clean. I've had much better luck with ArmorAll and Autoglym brake dust repellent...
https://www.armorall.com/ca/product/...ust-repellent/ https://www.autoglym.com/wheel-protector Nigel |
10-14-2022, 12:52 AM | #14 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Won’t this show up on our dark 1LE rims? The second brand says not to use on black rims.
