05-30-2017, 08:52 PM | #43 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
One more thank-you, OP(cwebster) and to you TJay- I've already changed the engine oil (X2 now), and got the rear diff while she's up on jack stands (used the GM gear oil called for by the owner's manual with the friction modifier already included).
Gonna support the trans and drop that cross member in the AM and put in 4+ quarts of RP Synchromax. Really appreciate the insight guys! |
05-30-2017, 11:52 PM | #44 | |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
715whp/665tq
05-31-2017, 12:41 PM | #45 |
Just to add a couple details to this procedure if you are removing the cross brace-
Besides the 4 primary 15mm bolts holding the cross brace be aware of the inverted (when lying on your back with car on jack stands) 18mm bolt at the back of the brace and then be ready with a 13mm socket for the 2 last nuts still holding the brace in place. Now you're ready to remove the last 2 15mm bolts holding the sub-brace in place... and then you can see the drain plug clearly! O.K., edit and beer break time... I drained out approximately 3.6 quarts with a small amount of spillage (50ml maybe). That's with car up at all 4 corners but the nose looks to be a little higher which I think would benefit the draining. So it looks like you'd be safe with purchasing just 4qts. However, after a couple more sips of brew... I'll go see how much I can pump in and report back. Also just for FYI, for lack of official numbers and just going on what the bolts felt like coming off, I tightened the 15mm bolts to 35 lb/ft, the 13mm to 25 lb/ft, and the 18mm to as tight as I could get it due to the difficulty accessing it. She's tight but not too tight, if you know what I mean. One more edit (and beer)- she took 3.85 quarts to fill. Also the drain and fill plugs do not require much torque. I began thinking I'd use 24lb/ft like the rear diff plugs call for but quickly saw that would be excessive so I stopped and just gottem snug with fresh lock-tite. Have fun guys! Last edited by Ventmaster; 05-31-2017 at 02:58 PM. |
05-31-2017, 06:36 PM | #46 |
Bring It
So I saw above the trans was supported. I haven't looked under there, but is that necessary? I know it was in the 5th gen when changing the shifter for example.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
05-31-2017, 09:57 PM | #47 | |
I just used my floor jack under the trans while the cross member was off. Also be aware I learned if you just remove the 6 15mm bolts that are easily accessible to you under the car, the brace/sub-brace will come off as one unit and simplify the process. Chevy was kind enough to cut a window in the middle of the brace so you can reach the bolts holding the sub-brace. Now you can leave the 18mm and 2-13mm bolt and nuts alone. Have fun. Last edited by Ventmaster; 06-01-2017 at 04:03 PM. |
06-11-2017, 12:22 AM | #48 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Changed my M6 oil today.
Removed the cross member real easy 6 bolts. My car did NOT have Magnetic plugs on the tranny. Wish it did ALOT of metal shavings in the oil at 1500 miles. I must say, I used the GM oil. Tranny shifts ALOT better now. Guess I'll order one MAG plug and put it in the fill hole.
ZL1::J-E-T-S JETS JETS JETS |
07-03-2017, 03:22 PM | #49 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
"IMPORTANT: Transmission fluid level setting must be followed exactly as written or the transmission may be overfilled or under filled. For fluid recommendations, Refer to Adhesives, Fluids, Lubricants, and Sealers (MM6) Transmission fluid level MUST be 3.2 mm (1/8 inch) below (1) the fill plug. This can be done by one of the following methods: 1. Bend mechanics wire to 3.2 mm (1/8 inch) to check fluid level. Add or remove fluid as necessary. 2. Fill transmission until level with the bottom of the fill plug hole, then remove 240 ml (8 ounces) of fluid."
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
07-04-2017, 09:40 PM | #50 |
One other thing I noticed is that the service manual specifies to use the temp sensor to drain the trans fluid. This is much more accessible, but it's hard to tell from the pictures if it's as low as the actual drain plug.
Does anyone with an SS actually have a magnetic drain plug on the trans?
07-08-2017, 03:17 AM | #51 |
manual also states fill is 1/8" below fill hole. http://www.camaro6.com/forums/showthread.php?t=500494
07-08-2017, 07:55 AM | #52 | ||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Do you have a personal copy of the service manual? If so, where did you get it? I'd like to get one for myself. Quote:
--Cal |
07-08-2017, 08:13 AM | #53 | |
Cal
--Cal |
07-08-2017, 11:07 AM | #54 | |
The full Helm's manual is available for $250 (electronic copy), but only the MY16 one is available. Once the MY17 one comes out, I'll be getting it.
07-08-2017, 11:08 AM | #55 | |
07-08-2017, 04:28 PM | #56 |
The transmission support and transmission mount should be removed as an assembly (as mentioned above.
4 bolts for the trans support crossmember. Torque spec = 58 Nm (43 lb ft) 2 bolts for the trans mount. Torque spec = 58 Nm (43 lb ft)
