01-10-2019, 12:55 PM | #1 |
LT1_Radenso
Drives: a 2 spd water bottle Join Date: Sep 2017
2019 SS 1LE Quarter Mile and 0 - 60 REVEALED!
During a Road and Track competitive review, the 2019 Chevrolet Camaro SS 1LE's track time was revealed, being on par with the 2019 Ford Mustang GT (As expected from GM). It does 0 - 60 in 3.9 seconds, which is about a tenth of a second faster than the pre-facelift SS 1LE, and this is only in manual, meaning the aerodynamics seem to be really 'paying off'.
You can expect the standard Camaro SS with 10-speed to offer 0 - 60 in 3.8 seconds. |
01-10-2019, 01:03 PM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Yes, the technical explanation is the air wants to get away from the ugly, so less drag. It's genius imo.
01-10-2019, 01:53 PM | #3 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Aerodynamics impacting 0-60 sprint? That's enough internet for today.
01-10-2019, 01:54 PM | #4 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The 1/4 mile time (12.3) is identical to runs produced by the '16-'18 SS / SS 1LE. That 0-60 time is within run to run variation. Not even GM is advertising an acceleration improvement with the refresh.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
01-10-2019, 02:08 PM | #5 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
0-60 is really a dumb matrix.
So much of it depends on tire condition, road surface, ambient temps., the operator working the clutch and throttle. A better matrix is the rolling 5-60 or whatever you want to use. But even then, just new tires to old tires can change that number quite a lot. Maybe this car had brand new fresh tires.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
01-10-2019, 03:10 PM | #6 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Frontal area aero doesn't really come into play until well after 60mph. Since 0-60 is a static variable, anything short of a massive rear wing won't play a role. It's more likely they got a better sample of the LT1 under the hood than their previous test car.
They should really stick these cars on a climate controlled dyno so they can also record that information before comparing 1 year versus another. More likely to glean a proper explanation for certain results "within the noise", as Motor Trend likes to call it. |
01-10-2019, 03:29 PM | #7 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
since when do they now limit the speed to 165. it states drag limited, but that isn't even close to being right... its like 180ish
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
01-10-2019, 07:14 PM | #8 |
LT1_Radenso
01-11-2019, 09:24 AM | #9 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Incorrect, the Camaro SS is not speed limited, it is drag limited. I have been in the OEM calibration and there was no limiter in my 1LE calibration.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
01-11-2019, 11:53 AM | #10 |
There is a limiter for the A8.
2016 NFG 1SS A8
01-12-2019, 11:18 AM | #11 | |
Where in the OEM calibration did you look for the limiter in your 1LE? |
01-12-2019, 02:05 PM | #12 |
2016 Camaro SS A8 stock tune file.
2016 NFG 1SS A8
01-13-2019, 03:58 PM | #13 |
Drives: 2SS 1LE Join Date: Oct 2011
M2C should take it every day in a straight line, they are dynoing around 405hp and 450-475tq, at the wheels, compare this to the SAE HP/tq of the LT1 measured at the crankshaft. Add the 7spd DCT and about 100lbs less weight, it's no mystery why it'll go faster in a straight line...around a track however, the 1LE kills it.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
02-06-2019, 04:49 PM | #14 |
Drives: 21 SS Join Date: Oct 2017
Bump because I don't know how this thread got here
