11-15-2020, 05:33 PM | #1 |
Drives: Red Camaro Join Date: Dec 2017
Dropping oil pan without removing engine
Does anyone have any suggestions other then removing motor to take the oil pan off. I dropped the lifter tray bolt down into engine. And really do not wanna rremove the engine. Is it possible to somehow lower the oil pan so.i wont need to remove it. Thanks
Sent from my SM-N975U using Tapatalk |
11-15-2020, 08:05 PM | #2 |
Should be enough room to drop the pan an run some kind of extendable magnet down in there or if you’re really daring you can cut the cross brace out an flange for pan removals like on a 5th Gen
Orange Krush II
11-17-2020, 07:05 AM | #3 |
Its not an easy job and we've done it to check bearing. Seems like we had to raise the motor just a little and you still have to take a bunch shit off to get it done, just no wiggle room.
11-17-2020, 07:46 AM | #4 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
I once forgot to take out lifters during a cam swap and dropped 5 of them into the block of my LS1 like an idiot. Most of them found the oil pan but I couldn't find the last one for a few hours. I had to back spin the crankshaft a few degrees and eventually found it on top of the windage tray. Only dropped the oil pan an inch or two and used a bending extended magnet thing to find them all.
11-17-2020, 07:49 AM | #5 |
Drives: 17 krypton green 1le Join Date: Feb 2017
I’ve been researching this to do cam swap and the consensus is loosen motor mounts to raise engine as much as possible and lower cradle some too. There are some on here that have done it maybe they will chime in. There seem to be no real shortcuts and one must choose the lesser of two evils here. Some think it’s easier to pull engine.
I’d like to see an aftermarket company develop a special gasket or maybe oil pan to reduce the clearance necessary to get it back on like that. |
11-17-2020, 02:09 PM | #6 | |
11-21-2020, 12:25 AM | #7 |
Will be trying it this weekend. I will fit motor up and drop the cradle a little and hopefully I can get to the bolt. Pray i can. Because taking the motor will make me spend more money tbh haha
Sent from my iPhone using Tapatalk |
11-21-2020, 05:39 AM | #8 |
Drives: 2018 1SS M6 Join Date: Feb 2018
i have not tried this but i have removed engine/trans. I would try unbolting motor mounts. drop the cradle about 2 inches. you WILL have to unbolt the trans too. This is because you are gonna hit the the body with the bell housing before you have enough room. so unbolting the trans should let you slide it forward enough to allow you to lift engine high enough.
also i seen someone say they wanna do it this way doing a cam swap. I dont know if thats a wise idea, it would be hard trying to clean up and do a good seal on the timing cover and be rough lining up your oil pump with how little room there is to work.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
11-21-2020, 07:54 AM | #9 |
We never dropped the cradle, hopefully your doing this on a lift cause it would really be a pain in the ass on the ground. Good luck
11-22-2020, 02:05 AM | #10 |
Well looks like motor is coming out
11-23-2020, 11:38 PM | #11 |
Motor pulled. It was easier to do rather then dropping oil pan. But pulling trans from
Motor was very difficult. Overall it was done. Now time to spend more money for drop in pistons and rods. Sent from my iPhone using Tapatalk |
