07-10-2018, 09:58 AM | #1 |
Drives: 2018 camaro 2lt rs silver ice metal Join Date: Jul 2018
Tire Question
I was wondering if 275 tires will fit on the stock rims that come with the 245s for the 2lt model?
Thank you. |
07-10-2018, 12:20 PM | #2 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
While they will fit, they wont fit correctly. The 245 are on a 8" wheel, the 275 are on a 9" rim.
07-10-2018, 03:26 PM | #3 |
07-11-2018, 11:24 PM | #4 | |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
They would look funny, they would be hard to mount (shops might decline to do it since I think it's below the recommended wheel width range for a 275/30), and the section width of the tire on the pavement wouldn't go up as much as you'd expect for a tire that is nominally 30mm wider. If you are going to get wider wheels down the road, consider going beyond 9" for a 275. It gets complicated because offset and wheel spacing are different for the front and rear axles when you get wider wheels and tires, so do your research before you spring for set of wheels. |
