Roto-Fab
Old 11-05-2010, 05:01 PM   #1
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Twin Fuel Tank Setup
I need a vendor here who can help make this happen.
I want to have an additional fuel tank and be able to switch between the stock and the second tank.
The stock one will be used for low(7-10) psi on pump gas and the other for when you flip the boost controller switch to high(11-18 psi) boost with race(VP 109 or C16) gas.
What would be the best solution for this? Maybe add another pump in the tank to supplement the stock unit and add a fuel cell with a single A-1000 or triple pump setup?
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 11-05-2010, 05:12 PM   #2
nl12
Drives: Unicycle
Nelson racing does setups like that, but I think they charge $$$$$
nl12 is offline   Reply With Quote
Old 11-05-2010, 06:12 PM   #3
SRT10KLLR
They are here in SoCal so I gave them a call on Wednesday but have not received a call back. Did not see them at SEMA but they usually go so maybe they will call sometime next week. I have seen some of their builds with two tanks but they use a stand alone pc to control everything.
I am thinking maybe relocate the battery and use the spare tire well for the extra tank.
Old 11-05-2010, 07:02 PM   #4
ADM PERFORMANCE
Drives: Anything I want
If you can afford all that work,you can afford C-16 all the time.
C-16 Will work at 6psi boost!
ADM PERFORMANCE is offline   Reply With Quote
Old 11-05-2010, 07:23 PM   #5
SRT10KLLR
The camaro is a dd street car with weekend track outings. It makes no sense to drive around in C16 all the time plus getting race gas imported over there is not the easiest thing in the world.
How much would it cost to do? 1K, 5K etc.?
Old 11-05-2010, 07:25 PM   #6
ADM PERFORMANCE
Depends on the power level...My estimate would be 5k+
Old 11-05-2010, 09:20 PM   #7
nl12
Drives: Unicycle
Maybe run e85? or use a meth system, with a built low compression motor you should be able to run 18 psi on pump gas with a meth system or on E85. But Im no expert just my opinion. I always thought those dual tank setups were for people wanting over 1000whp, if thats not what your after then I dont think you need it IMO.
Old 11-05-2010, 09:40 PM   #8
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Nelson Racing Engines is very hard to get a hold of. Always busy, but worth it. Anyway, here is the Octane-on-demand system we put in to the SST Camaro.
Twin tanks - One 93, One C-16. Can both be filled with C-23 for crazy boost.
Built in Pumps and filters. This is the A1000. The other tank has the A1004.
Here is what they look like mounted with the access portals.
The explanation of the components used and how the system works is in post 101 of the SST build if it helps at all.
speedster is offline   Reply With Quote
Old 11-06-2010, 12:52 AM   #9
SRT10KLLR
That's for both tanks right? Even on low boost I don't think the stock pump will be enough.
Talk about go big or go home.
I was thinking something a little more simple. Stock tank with twin pumps plus an additional tank in the truck with the A-1000 or something like that.
If you don't mind me asking how much was it? You can pm me the price if you don't want to post it here.
BTW, who built it?
Old 11-06-2010, 07:29 PM   #10
walkermuffler
Drives: 2010 ss
my tank system!
E.P.S. just finished my fuel system! trunk is clean!!!
walkermuffler is offline   Reply With Quote
Old 11-06-2010, 11:51 PM   #11
SRT10KLLR
The Camaro currently has a built 416 with p&p heads, cam, headers etc. But, the heads will need to come off to put the stock heads back on and use a thicker gasket to lower the cr to 9.2:1. The ported heads were milled to raise the cr for n/a before thinking about f/i.
There is no E85 anywhere around these parts. Whatever she can handle on pump gas will be low boost. Then high will be on race gas(100, 109 or C16 those are available on a limited basis at the track).
The TT should do well just have to decide which one to get(Hellion, IPS or TTi). Not stuck on any hp or psi but rather ET. Just need to get at least into the 9's.
I started researching as soon as you posted that. It looks pretty straight forward. It is a drop in cell for any car. So, just add the pump, filter, lines etc. to complete.
Probably with have the cell made out of metal(aluminum, stainless steal etc.) instead.
Old 11-07-2010, 01:38 PM   #12
Slowhawk
Drives: 1999 Trans Am
Your setup is pretty basic.I would just suggest a duel intank pump setup and a good methenol system. We have many low 9 second vehicles running this setup.When they go to the track they just add some 104 unleaded for added safety.
I would stay clear of Nelson racing for awhile. Have a few customers waiting for parts and have been for 1-2 years. There are other good shops out there that would custom make anything for ya.
Slowhawk is offline   Reply With Quote
Lethal Performance/ Fore Precision Fuel Hats- CHECK THIS THING OUT Jared@Lethal Forced Induction 3 08-12-2010 11:30 AM
fuel tank sloshing riderguy999 5th Gen Camaro SS LS LT General Discussions 8 03-17-2010 01:54 PM
Fuel tank release sigma_1966 5th Gen Camaro SS LS LT General Discussions 1 06-21-2009 08:28 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
