08-09-2019, 08:38 PM | #1 |
Drives: 2004 Silverado, 2020 ZL1 Join Date: Oct 2016
Knock retard at the drag strip
So I've got a stock engine except for a ported throttle body and I'm getting about 3 degrees of knock retard on premium. Any ideas? Is This normal? Thanks
08-10-2019, 05:31 AM | #2 |
Sounds like you need some custom tuning. Ported TB shouldn't cause that, is yours an SS, Zl1?
08-10-2019, 07:47 AM | #3 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
You need higher octane fuel. Do you have 92 at the pump there?
08-10-2019, 08:22 AM | #4 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
If you are running 91, yes it will be normal. Even if you are on 93, it could be very possible depending on how hot it was outside and what the intake air temps were going into the motor. At the least, run at least 93 if you are going to track the car. If you have E85 you can add 3 gallons to a full tank of 91 or 93 and it will give you a nice octane boost and help with detonation.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
08-10-2019, 09:56 AM | #5 |
It's a SS. The best I can get here is 92 octane and the iat at launch was about 130 or so. It calmed down a bit and was pulling timing less often, bit still a degree or 2 especially around 5200-5400.
08-10-2019, 10:19 AM | #6 |
Dumb Ass Deluxe
You can try the E. I don't know how much you'll pull the octane up. It would be cheaper.
If you go to Home Depot or a paint store and get 1 gal of Xylene and throw it in the tank to every 9 gal of 92 You should be @ 94.5 octane. 2 gal will take you to 96.5. Doubt you'd need 2 gal though for 2-3*. If it clears it up with one, back it down until you get the knock again and you'll know exactly how much you need (1/2 gal, 3 qt). I don't know which would net you more hp. I'm guessing option B. You lose a little cooling effect but gain btu content. Try both ways and see what it does to your top end #'s. |
08-10-2019, 10:54 AM | #7 |
You need like 60* iats to see if you have excessive kr on a stock tune.
08-10-2019, 11:03 AM | #8 |
The da at the end of the night was around 1300. And my mph hovered right around 112. they have one night for test and tune open in October and hopefully that one won't get rained out. Is the xylene different than octane booster?
08-10-2019, 11:12 AM | #9 |
How much timing is it running? 21*?
08-10-2019, 11:28 AM | #10 |
How do you know timing was being pulled, what are you using to data log?
If the Intake Air Temps were around the 110°-130° range that may have been timing pulled from the IAT table. It starts pulling timing at 85° of intake air temp.
08-10-2019, 09:37 PM | #11 |
Dumb Ass Deluxe
It's one of the components they use to make gasoline. Used as a straight up fuel, it is 117 octane. They probably do use it in octane booster as well, but the small quantity in the bottle doesn't raise the octane high enough to do any good.
08-10-2019, 10:18 PM | #12 |
I'm using HP tuners and logging runs. I do believe it was 21 or 22 *. I'm still getting used to it all and that was only my second night at the track.
08-11-2019, 07:13 AM | #13 |
I think you’re good. Stock tune is Aggressive and designed to have kr
All in is 24* in cool weather and 93 octane.so 22 in the heat is fine |
08-11-2019, 11:19 AM | #14 | |
final advance PE advance IAT advance coolant advance knock retard torque management advance Log those and then try it again, that will tell ya what is really pulling the timing.
