08-23-2018, 12:07 AM | #1 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
Homelink Functionality
The Homelink in my Camaro works very poorly in such that when my car is at different angles to the garage door motor, it does not operate.
I'm wondering if this has anything to do with the tank-like design of the Camaro. Thinking that the signal is blocked by short window height openings. Is this unique to me, or is it common? |
08-23-2018, 12:23 AM | #2 |
Drives: 2018 HBM 2SS/1LE Join Date: Jun 2018
I have 2 doors programmed into my car, mine and Mom's.
At Mom's house I can hit the button about 50 yards from the house and her door opens just fine. At my house I have to get the nose of the car less than 2 feet from the door to open it
2017 Admiral Blue Corvette Grand Sport Convertible
08-23-2018, 01:55 AM | #3 |
mine works fine. how well does the remote work. maybe its you opener antenna.
08-23-2018, 02:55 AM | #4 |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
Same here. I could always hit the opener in the car about 25-50 yards depending on the car. I pull the Camaro to the door and have to hit the button 3-4 times every night. It's not a huge deal, just noticeable.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
08-23-2018, 03:03 AM | #5 |
actually i just remembered the last 2 times i used mine i had to press it twice. closer then usual.
08-23-2018, 03:31 AM | #6 | |
I was thinking that the Camaro just had a shorter range than other remotes until I programmed Mom's door and it works from the other side of her neighborhood Maybe I'll try to reprogram it.
08-23-2018, 07:47 AM | #7 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
My 17 Camaro works at twice the distance of wife’s 18 XT5 on same door no matter the direction.
08-23-2018, 08:22 AM | #8 |
Drives: 2017 Camaro RS Fiftieth Anniversary Join Date: Oct 2017
I noticed poor performance as well, all other cars I have had worked well, including my wife's current vehicle a 2007 Lexus. I have to be sitting in front of the door for the Camaro internal remote to work and sometimes it needs multiple attempts if it works at all. I've given up and I now keep the an additional remote in the car for the times it just doesn't work.
08-23-2018, 09:41 AM | #9 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Mine works great, open it eve before I get to my driveway, works every time! I have a 13 year old Genie screw drive. Probably the antenna on the opener, I make sure might hangs down from the unit all the time.
08-23-2018, 09:43 AM | #10 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
Mine work great, had a problem with initially connecting to the garage door opener but I think that was more operator error
08-23-2018, 09:49 AM | #11 |
Sucked at my old house on all 3 Camaros; 2010, 2014, and 2017. Current place it works just fine on the 14 and 17...
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
08-23-2018, 09:53 AM | #12 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
+1
08-23-2018, 10:20 AM | #13 |
LFX to LT1
Drives: 2017 Camaro Fifty 2SS M6 Join Date: Feb 2014
The remote opener that clips to the visor in my DD works from a reasonable distance.
I have to wait until I'm literally in front of my driveway, ready to back into the garage, before the Homelink button in the Camaro will open the garage door.
2013 Rally Yellow 1LT - Traded
2017 Camaro Fifty 2SS; Sequence #270 - Sunroof/Nav/NPP/MRC/6speed |
08-23-2018, 10:43 AM | #14 |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
Won't be a problem at all in my 2019 seeing as they just flat out removed it!
