02-21-2017, 11:59 AM | #15 |
Drives: 16' Camaro E-Force SS Join Date: Jul 2016
I wanted to bump this old thread now that i have my s/c in. It's WET WET WET in california. SOAKING.
however, i can confirm launch control works the exact same with the edelbrock s/c (stock eb tune) as it did with a stock car. comp mode, mash brake, mash gas, launch. Even in the wet ground the car limited the wheel spin and sent me on my way. 0-60 was probably 25 seconds though as it was so wet outside I'll do some more testing whenever it stops raining (maybe never) Edit: appears that launch control doesn't work after all. More testing to follow. Edit 2: Appears it does work. Ha.
Leo
2016 e-Force 2SS Instagram @cleoent Last edited by cleoent; 02-24-2017 at 03:51 PM. |
02-21-2017, 02:49 PM | #16 |
Drives: 2016 2SS Join Date: Nov 2011
With the torque these cars are making you will blow the tires plum off and most tuners turn off LC. I mash the brake and load it up to 2000 rpm, launch when ready. It worked very well at the drag strip the other day with MT's.
Who Dares...Wins |
02-21-2017, 09:38 PM | #17 |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
if you have a manual, just drop the clutch a little slower and you'd probably be fine
02-22-2017, 09:32 AM | #18 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Has anyone with a supercharged A8 had success launching in 2nd? I only got 800 miles on mine before putting it away for winter and I still only had the stock wheels and tires, but I couldn't hook up at all in 1st. When i tried launch control it would start to spin the tires then stop and bog and then repeat until i let off the brake. (Was I not holding the brake hard enough?) I never got around to trying the 2nd gear launch and the roads were cold in PA in November. I'm sure I will figure it out this spring, but just wondering if anyone has tried this?
02-22-2017, 10:05 AM | #19 | |
Who Dares...Wins |
02-22-2017, 12:33 PM | #20 |
Was the 2nd gear launch faster in your attempts? Hooking up instead of spinning?
02-23-2017, 02:30 PM | #21 |
02-24-2017, 12:20 AM | #22 |
Today's testing revealed that launch control doesn't work. Or at least I couldn't get it activated today.
I have no idea how to launch this car now. No traction at all until 80.
Leo
2016 e-Force 2SS Instagram @cleoent |
02-24-2017, 07:22 AM | #23 |
Drives: 2016 2ss Join Date: Jun 2016
So what about traction control? If you mash on it at 20 mph with all the nannies on?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
02-24-2017, 09:09 AM | #24 |
02-24-2017, 09:48 AM | #25 |
Spin. Sideways movement. Then correction.
Leo
02-24-2017, 12:32 PM | #26 |
Drives: Many C7's Join Date: Apr 2014
02-24-2017, 02:21 PM | #27 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Yes it's like a training aid for driver traction control. If the nanny kicks in you effed up.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
02-24-2017, 03:54 PM | #28 |
I did more testing today, and today launch control was working and it was great.
I tried launching in track, sport, and tour from second gear (full traction control on), and was always between 4.2 and 4.6. I tried short shifting into 3rd (as the car struggled for traction) and no matter what i did, i was between 4.2 and 4.6. Then I gave launch control another shot. In sport, competition mode. Mash brake, mash gas. Here's the result. Pretty stoked. I also tried competition mode, and just a little brake, about 1k rpms and almost ended up facing the wrong way on the road, so I can confirm that launch control is active and keeps you pointing straight when it is engaged (see the 1.2 second 0-60 run, needed to change my shorts there).
Leo
