03-10-2022, 04:31 PM | #1 |
Drives: 2020 Chevrolet Camaro 2SS 1LE Join Date: Feb 2022
New 1LE rotors
Yesterday I had new rotors installed on my 2020 2SS 1LE by my local dealer. They replaced them on warranty but I noticed these new rotors are slotted. I know the original rotors aee part #s23142500, 23189768. They replaced them with 23245480 and 23245481. I'm I good with these? Or should I be getting the dealership to install original 1le rotors? Can't seem to find anyone with these on their 1le's.
03-10-2022, 04:46 PM | #2 |
the top ones are the 6 piston performance kit rotors and the bottoms are the oem 1le rotors
03-10-2022, 04:50 PM | #3 |
03-10-2022, 04:54 PM | #4 |
Drives: Chevy Camaro Join Date: Jan 2022
Someone posted a breakdown of the different brake options on here, as long as the dimensions for the two shown options are the same I'd imagine you're fine. If diameter differs I'd be worried
'22 2SS 1LE manual in Red Hot with Red seat belts, alloy pedals, PPF, catch can, and suede kneepads.
03-10-2022, 04:54 PM | #5 |
they will work just fine are you going to be tracking the car or no?
03-10-2022, 05:03 PM | #6 |
03-10-2022, 05:11 PM | #7 |
im sure it will be fine but not sure why they put on those rotors instead of your oem ones
03-10-2022, 05:13 PM | #8 |
I am wondering the same thing myself. Thanks for the info.
03-11-2022, 06:57 AM | #9 |
Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
I'd bet that parts availability has something to do with why the dealer used that rotor.
03-11-2022, 02:20 PM | #10 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Sep 2018
I have the slotted rotors on my car..they work just fine. Besides, they are more expensive than the other. I would just go with it if I were you.....
03-11-2022, 02:33 PM | #11 |
Drives: 2022 Camaro ZL1 Join Date: Dec 2021
The slotted rotors are what's on my C7 Grand Sport. I was surprised the ones on the ZL1 are not. You should be fine with those.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2016 Hyundai Equus Ultimate 1971 Datsun 240Z |
03-11-2022, 02:48 PM | #12 |
Drives: Pontiac GTO Join Date: Feb 2022
My experience with tracking Corvettes and Mitsubishi Galant VR-4s, I found the slotted rotors superior to plan rotors as they allowed an escape route for hot gases not to mention pad dust. Drilled rotors tended to crack under hard use. Cast holes rotors seemed to work well, although not superior to slotted rotors. Just my experience and observations from 20+ years of track experience.
03-11-2022, 04:01 PM | #13 |
They probably cost you more too
03-12-2022, 02:42 AM | #14 |
Drives: Blue ss 1le 18 Join Date: Apr 2018
How did you get rotors replacement under warranty ?
If the dimensions are the same then you are good to go, might have slightly more pad wear with slotted but better for track. |
