01-09-2020, 12:32 PM | #1 |
Drives: 2017 Focus RS Join Date: Nov 2017
Picture Request
If anyone has too much time on their hands and wants to do me a favor....
Could you take some large/hi-res photos of the engine bay from different angles with the engine/plastic beauty covers removed? I took some before and now I can't find them. |
01-09-2020, 12:51 PM | #2 |
Or if you already know where some are posted, threads or a instragram account, etc, please let me know.
01-09-2020, 01:18 PM | #3 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
I have 1 at least here
https://www.camaro5.com/forums/showthread.php?t=527371
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
01-09-2020, 01:22 PM | #4 |
I can get you some when i get home, what did you need.
01-09-2020, 02:40 PM | #5 |
Honestly,
Just some good photos of the bay with the glamour covers removed from the engine (for hose, wire, etc routing clarity) -From front of car down-ish and towards the rear -From Driver's fender towards passenger side -From Passenger's fender towards driver's side -From about driver's front tire towards cooling system (hoses and whatnot routing). Trying to get this car buttoned back up and boy does it have a hell of alot of wires, hoses, etc. I just keep running into "How did this wire get routed?" and "Where does this clip go?" I appreciate the help. |
01-09-2020, 03:32 PM | #6 |
Drives: . Join Date: Jun 2016
Not quite stock, but the only things I have moved are the coil packs are mounted direct to the Holley valve covers. Everything else I believe is routed as per factory.
Maybe it will be a help to you anyway.. |
01-10-2020, 07:53 AM | #7 |
Nice, thank you. These will help me make sure I have things
Any chance you (or someone else) have a picture of the backside of the radiator/dry sump tank area? Most of the connections are obvious but want/need to check the fan connection routing, etc. |
Thread Tools | |
