Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 10-18-2019, 11:15 AM   #1
47Ronin
Drives: Camaro Z/28 - 2015
ZL11LE wheels on Z28 - does it work?
Would the original wheels of the ZL1 1LE fit on our Z28?
The dimensions at the front are identical. So it should fit in the front easily, right? And the rear?
If it does not fit easily, is there any solution for that? Has anyone tried that?
47Ronin is offline   Reply With Quote
Old 10-18-2019, 12:54 PM   #2
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
Z/28
F 19x11 +11 305/30/19
R 19x11.5 +32.25 305/30/19
ZL1 1LE
R 19x12 +41 325/30/19
use this tool to understand the size variance with the rear
https://www.rimsntires.com/specspro.jsp
Additionally a few people have reports with different size tires on the rear v the front, the Z/28 traction control, ABS, Stability systems get upset
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 10-18-2019, 12:56 PM   #3
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
As far as I know on a Z/28 the front and the rear is different in rim size. Tires are the same, but the rims are different. Front is 19"x11" (48.26 cm x 27.94 cm) rear is 19"x11.5" (48.26 cm x 29.21 cm) and they can not interchange front to rear or rear to front. I've had first hand experience with this at a tire shop. Where they mistaken and installed rear to the front. Bunch of "Scheisse Kopf"
https://www.camaro5.com/forums/showthread.php?t=369676
This old thread might help. Good luck.
Besides why would you want to change out the Z/28 wheels for ZL1. Original Z rims are hard to get.
pzero is offline   Reply With Quote
Old 10-18-2019, 02:04 PM   #4
Jeff71
Drives: 2015 Z/28 #1251
He was asking about ZL1 1LE 6th gen. wheels, not the 5th gen ZL1.
Jeff71 is offline   Reply With Quote
Old 10-18-2019, 06:19 PM   #5
47Ronin
YES - not from the ZL1, from the ZL1 1LE 6th Gen.! ��
Thanks for this site, Jon.
If I understand correctly, I need a spacer that is 15 mm wide. Or what do you mean?
Old 10-18-2019, 06:27 PM   #6
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I have no insight into 6th gen ZLE wheels but I am running 305s front and 325s rear with no issues.
69L48Z27 is offline   Reply With Quote
Old 10-18-2019, 06:47 PM   #7
47Ronin
https://www.camaro5.com/forums/attac...1&d=1571442243
Old 10-18-2019, 07:41 PM   #8
j o n
j o n's Avatar
Why are you saying 15mm?
Current:
Sold:
Old 10-18-2019, 07:47 PM   #9
47Ronin
Because the backspace of the 1LE wheel is 15 mm deeper.
Old 10-19-2019, 07:51 AM   #10
j o n
j o n's Avatar
I see what you mean now... 207-191=16mm. Don't pay attention to that measurement though.
Just pay attention to offset
The z/28 owner above runs 325s without issue he says, with his +32.25 oem z/28 wheels. So with 325s on a +41, that's roughly 9mm closer to the inside of the wheel well. However as the pics show of the calculator, the tire is flush with the opening of the wheel well. So you don't want to go too far more outwards. I doubt you need a full 9mm, if at all. Start with 3-5mm. You'll be fine
Current:
Sold:
Old 10-19-2019, 01:38 PM   #11
Biergut
Biergut's Avatar
Drives: '15 Z/28
47Ronin --
This page might make it a little easier to visualize --
https://www.1010tires.com/Tools/Whee...et-Calculator#
Biergut is offline   Reply With Quote
Old 10-19-2019, 04:10 PM   #12
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Do you want a pic of a rear ZL11LE rim with factory tire on a Z/28 ? If yes I will take it in the morning, let me know.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-19-2019, 07:14 PM   #13
47Ronin
Yes, please.
And thanks to all for the great infos.
Old 10-19-2019, 07:20 PM   #14
47Ronin
Originally Posted by Biergut View Post
47Ronin --
Jon, this is the result from the calculator from your page:
Inner Clearance: the same
Outer Position: the same
Does that mean that I do not need any spacers?
Would it fit easily?
