12-27-2016, 09:23 AM | #1 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Longtube header install difficulty?
In the future I might consider headers for my 1LE. Is it possible to install longtubes at home using ramps or jack stands? I would run headers with catted mid pipes to stock NPP.
MJK3888 Instagram Link
12-27-2016, 09:44 AM | #2 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Doesn't really pertain to the new camaro alpha chassis but I installed long tube headers on my 5th gen camaro with putting 4 jacks stands under the car and had plenty of room that install them. Hope this helps.
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
12-27-2016, 10:17 AM | #3 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
I suppose if you wanted to you could. However, these are much harder to do than on the 5th Gen. There is front subframe brace that unbolts and swings down to allow clearance, so you have to be high enough for that. Also, you have to cut your stock exhaust to the length of the new mid pipes. Not the easiest thing to do on jack stands, but I imagine anything is possible with enough ambition.
URR2SLO - If you're not going fast enough, get out the way......
12-27-2016, 10:41 AM | #4 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
For what it's worth, I really don't want to do long tubes on a 6th gen but, if I did, I think I'd get the two piece Hooker setup. Sure, you may introduce some leaks but, I think with proper installation, it should suffice for its intended purpose. I can imagine that could be installed in your garage with jackstands.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold Last edited by USAFS197; 01-05-2017 at 02:49 AM. |
12-27-2016, 10:46 AM | #5 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
It can be done. I wouldn't do it, but it's worth it in the end. Sounds so good.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
12-27-2016, 11:11 AM | #6 | |
Drives: SS 6 speed of course Join Date: Jan 2016
I started a write up in the install. Will finish it this week. The "subframe" aka skid plate, takes all of a few minutes to unbolt that and the three plastic shields. Front needs to be 21.5" off the ground from K member to floor. Rear tires were 3" off the floor. Easy job. Easier than a LS1 Camaro and way way way easier than a L89 camaro.
12-27-2016, 01:50 PM | #7 | |
Drives: 2SS Join Date: Apr 2016
12-27-2016, 04:50 PM | #8 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
My shop charged 3.5 hours to do it on a lift.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
12-27-2016, 07:28 PM | #9 |
Drives: 2016 SS, BLACK, MANUAL Join Date: Apr 2010
I installed SW headers, hi-flow cats, 3" diameter pipes back to SW mufflers with 5" diameter outlets in my garage with the tires 19" off the ground and I am going to be 71 years old. Was one of the easiest header installs that I have installed in 55 years and I do all my own work on my cars. Just my $.02
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come. 2014 Camaro Ashen grey, 3.6, 6 speed, Vararam intake, Elite catch can, chrome wheels, and Vitesse controller. 2003 SSR red, 2016 Vette |
12-27-2016, 09:33 PM | #10 |
I put the two sons to work and "supervised".
12-28-2016, 06:24 AM | #11 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
You sir, win at life.
Less torture on your back and knees and they get valuable experience.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
12-28-2016, 07:35 AM | #12 | |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
12-28-2016, 10:53 AM | #13 | |
Drives: 2016 2SS Join Date: Nov 2015
12-28-2016, 11:31 AM | #14 |
retired badass
Anything can be done on jackstands I do it ok the time from transmission install on my ls1 to full exhaust system. Save money and do it yourself.
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts. Retired USMC |
