Old 09-17-2018, 08:18 AM   #1
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Aftermarket Mid Pipes
I currently have kooks headers and off road pipes tied to the stock NPP system. I have an A8 but the afm is tuned out. I'm looking for a mid pipe that will work with this set up, removing the crush pipes and the afm valves, and connect to the factory muffler. I have seen where the transmission tunnel brace is removed on some installations. I don't want to do that. The factory pipes seem to have a bend in them to get over tunnel brace, but all the aftermarket ones I see seem to be straight. I would appreciate what people are doing and how its being configured. Thanks
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 09-17-2018, 10:24 PM   #2
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Borla 60606 I think would work.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 09-18-2018, 09:32 AM   #3
Brianw36
SNSTRSS
Brianw36's Avatar
The Borla set up is 2.75 inches. I'm looking for 3 inch.
Old 09-18-2018, 09:43 AM   #4
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
https://www.phastekperformance.com/2...ves-s/1454.htm
https://www.corsaperformance.com/col...12452493754454
https://www.holley.com/products/exha.../70501387-RHKR
Check here
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
Old 09-18-2018, 10:07 AM   #5
Brianw36
SNSTRSS
Brianw36's Avatar
Has anyone used the speed engineering pipes with Kooks and stock NPP?
Old 09-18-2018, 11:02 AM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Yes. They dont "bolt together".... you have to do some cutting and either clamp them or weld them
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 09-18-2018, 11:08 AM   #7
Brianw36
SNSTRSS
Brianw36's Avatar
I understand that as it would be the same with any other aftermarket setup that was not Kooks. JUst looking for some pictures or tips on using the speed engineering setup seeing it is 3inches.
Old 09-18-2018, 11:49 AM   #8
danhr
BAMF SS
danhr's Avatar
The kooks off road connection pipes neck down to 2.75.... so just cut it at the reducer, that way it stays 3" the whole way. Put the speed engineering pipes up and cut where they overlap.... then weld together. They have the same bends, so it's pretty selfexplanatory. Iirc, the speed engineering pipe gets cut right after the o2 bung, because I was hoping to use it for my wideband, but had to cut it out
Stock Longblock
Old 09-18-2018, 12:26 PM   #9
Brianw36
SNSTRSS
Brianw36's Avatar
Thank You Danhr. I take it you have used these. How is the quality? Did you have to remove transmission tunnel brace?
Old 09-18-2018, 12:50 PM   #10
danhr
BAMF SS
danhr's Avatar
well they are listed in my signature, but yes. lol.
I have kooks 2" headers, to the off road connection pipes, mated to the speed engineering x pipe, which goes back to my factory NPP exhaust.
I kept the tunnel brace, but had to use like 1/8th or 1/4" spacers to get it down a little bit.
welds on the speed engineering stuff looked better than the welds on the kooks
the clamps speed engineering sends kinda suck... but meh....
Stock Longblock
Old 09-18-2018, 01:04 PM   #11
Brianw36
SNSTRSS
Brianw36's Avatar
I missed that. Thanks for helping a brother out.
