12-28-2018, 10:25 AM | #1 |
Drives: 2016 Camaro SS Join Date: Sep 2018
17 inch drag pack tire size?
Been seeing/getting conflicted answers. Should I run a 26 inch tire or a 28 inch tire on a 17 inch drag pack? If I should run a 26 will it mess up the T/C and stabilitrac and if I need to run a 28 inch tore will it rub?
12-28-2018, 11:58 AM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
you can run a 26, just have to make sure all 4 tires are the same size. so if you want a 305 45 17 that equals to a 28 inch tire for the rear. don't offset more than ~1
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
12-28-2018, 12:09 PM | #3 |
Thanks. Just trying to figure out if a 26 is better or a 28 is better. I also feel like a 28 in the front would be too tall looking on a 17 inch wheel.
12-28-2018, 12:11 PM | #4 |
my front looks pretty meaty so i could imagine a 17 inch. i believe a smaller tire is better for grip.. but i'm no pro as i made the mistake of doing a 26 and 28
12-28-2018, 12:13 PM | #5 |
12-28-2018, 12:18 PM | #6 |
yeah you'd probably want to do a 26 inch in front and a 26 in rear. i think a 26 in rear is 275 40 17
12-28-2018, 12:42 PM | #7 |
12-28-2018, 02:48 PM | #8 |
Drives: 17 garnet red 2ss vert Join Date: Apr 2018
I'm running 315-35r17 Hoosiers, only problem I have is the traction control will kick on any time i get on it. I turn it off anyway so its not a big deal. Car dead hooks and runs about .4 second quicker.
01-01-2019, 05:15 PM | #9 | |
Sent from my SM-G955U using Tapatalk |
01-01-2019, 10:13 PM | #10 |
Its a 26 inch tire, still running the stock front. That way it messes with the traction control. Looking for a pair of 18 inch rims for the frount to run 245/35 18. Shoud be about the same size as the drag radials.
01-02-2019, 07:42 AM | #11 |
Ok thanks. I have been trying to decide if I need to run a 26 or a 28 inch tire and I can't get a straight answer anywhere. lol
01-03-2019, 06:53 PM | #12 |
Drives: 2023 LT1 A10 Join Date: May 2017
I was wondering the same thing awhile back...check this out:
https://www.camaro6.com/forums/showthread.php?t=537041
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6 |
01-03-2019, 07:00 PM | #13 |
I have a pair of 26x6x18 tires with 5 miles if anyone wants a 26inch front lol.
