09-22-2017, 03:33 AM | #57 | |
Drives: 17 Hyper Blue SS 1LE Join Date: Aug 2017
I will check my cables to make sure nothing rubbing on belts. It's the first thing I did when I got the car and all was ok. Reminds me to check the end links on front sway |
09-22-2017, 11:36 AM | #58 |
Drives: 2017 1SS Join Date: Aug 2016
Now Released the GMPP 50-State Legal LT1 Intake
http://thatcamaropartsguy.com/6-2l-g...eneral-motors/ |
09-22-2017, 01:04 PM | #59 |
Drives: 2017 2SS Camaro Join Date: Apr 2013
This is great news, does anyone have the final cost including installation? The link above from ThatGMPartsGuy.com notes "Customers that take it to a GM dealer to have the intake installed should not and will not be charged for labor to do the re-programming of the ECM. Dealers must charge the labor for the re-programming only to Labor OP 0601558."
09-22-2017, 01:17 PM | #60 |
From all the customer that I've worked with when it came to the service department, I've seen usual charge labor times to be 1 - 1.5hrs worth of labor, labor rates vary from dealer to dealer but it's anywhere from $120-180 range. The tune portion like you said is charged to GM themselves which is a standard hr of labor. Make sure they do not charge you for this portion.
09-22-2017, 01:21 PM | #61 |
Awesome... thank you. I live in So. Cal, I'll call around but will most likely go to Penske to have the work done.
10-01-2017, 10:55 PM | #62 |
what is this absorber thing that you do not remove?
10-02-2017, 12:15 PM | #63 |
The black portion of the MAF housing. I'm pretty sure that was on the Non-Carb design as well so I still think the only difference is the tune. |
05-11-2018, 12:55 PM | #64 |
Still Available
Wildhammer, are these still available from your site?
1967 Base 327 - numbers matching 10C car - (TruBlu - Marina Blue inside and out, still own)
1986 Base V6 - 1987 (Calif.) RS - 1995 Base V6 (all sold) 2017 2SS “Tribute FIFTY” in Blue (HBM, 56R, 5VM, MX0, F55, NPP, RN2, RZ9, S0O, S0V, IO6 Tribute RPO: BR9, FTJ, 56Y, CJL)#teamBeckyD |
05-12-2018, 09:47 AM | #65 |
Yes we currently have a couple in stock as of right now.
Side note GM Finally released the filter separately if anyone was looking for a spare http://wildhammermotorsports.com/cam...t-performance/ |
05-12-2018, 10:27 AM | #66 |
is the filter washable? not reading 5 pages to see if some one asked.
05-18-2018, 06:22 PM | #67 |
They made it available for a day and then GM turned it off again and put it back on "Future Part Status" we are currently working with Chevrolet Performance to fix this issue
05-18-2018, 06:55 PM | #68 |
