01-04-2017, 03:59 PM | #15 | |
Drives: 2017 Camaro SS Join Date: Aug 2016
01-04-2017, 04:12 PM | #16 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
01-04-2017, 05:35 PM | #17 |
Drives: SS 6 speed of course Join Date: Jan 2016
Yep, they did my supercharged Challenger... really top notch.
01-05-2017, 02:42 PM | #18 |
Jannetty just confirmed the pan DOES NOT NEED TO BE DROPPED... getting cheaper and easier...
01-05-2017, 03:07 PM | #19 |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
oldman... are you saying bybcous 's set up will need new springs and rocker arms every 20k miles?
you dont feel 500 whp is doable in a daily driver without tear downs every 20k?
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
01-05-2017, 04:09 PM | #20 |
New springs and rocker arms every 20k? Damn i was not expecting this, how much work is required to install those items?
1ss/Auto-Hyper Blue
01-05-2017, 04:25 PM | #21 |
Here is my full parts list, the only item I did not upgrade were rocker arms I believe, will I have problems eventually?
1ss/Auto-Hyper Blue
01-05-2017, 05:03 PM | #22 |
I'm going from my LS1 days. Lots of things have changed, but even in the early 2000s it was the same story... modern springs, modern bearings, modern break-in procedures you won't have a problem.... I've changed many many many everything on a LS1 that "won't be a problem".
IMO, trunion and valve springs on an aggressive lift ramp .660 lift cam will experience: spring fatigue, trunion wear and timing chain stretch pre-100,000 miles. While a .560 lift cam will not. When? I think LS3 guys would have a better gauge on that. I hope I'm wrong, but will leave it to guys that have been doing it over the last 10 years vs my 1997 to 2004ish experience. My autoX cars (both Hondas) I change valvesprings every 20,000 miles and yes they are the newest and greatest wizbang each and every time.. conical, shotpeen un0btanium alloy.
01-05-2017, 06:44 PM | #23 |
SABIO
So if You were to order a camshaft. How would You spec it out or what would you want to see on the Cam card? .5 Intake?/Exhuast?? Lobe seperation?
01-05-2017, 09:24 PM | #24 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
oldman, I'm guessing they are S2000's? Other than DOHC being rougher on valve springs in general, the S2000 is even more brutal with how many guys I've seen push the RPM range way up. That thing has a stout little motor for sure, but it practically eats itself alive to perform at that level.
For the LT1 w/ AFM, I would think any of the first 3 Comp Cam XFI AFM's will work fine with the stock valve train. If your cam specs are anything close the 624-500/512/524-13 cams, I wouldn't sweat it. If you went for a bonkers cam, like the 624-536-13 (or even more aggressive), pushing the RPM range well above 7k, then I would look into some regular valvetrain maintenance or would just forget keeping AFM to begin with and get some serious heads/valve/rockers/springs/retainers. Personally I think for those looking at an affordable cam job on the AFM models, the 624-524-13 can't be beat. I just wish it came with a little more fuel lobe to make it E85 friendly for those looking to make great numbers without boost. |
01-05-2017, 09:33 PM | #25 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Pretty much why I'm doing it in stages:
Stage 1 - Cam, springs, lifters, and forged pistons with all the nice little side items (wires, etc) Stage 2 - Some kind of FI after I get some miles on Stage 1 |
01-06-2017, 08:45 AM | #26 | |
http://www.camaro6.com/forums/showth...=444879&page=3 Don't get me wrong there is a lot of power to be gained from an aggressive ramp profile and a proper head package designed for a .660 lift cam. The stock head stalls out between .525 and .670 http://www.superchevy.com/how-to/eng...ylinder-heads/
01-06-2017, 08:46 AM | #27 |
Are the LT4 forged? Either way I'd go with the LT4 piston and ring.
01-06-2017, 09:07 AM | #28 | ||
I do like to keep the RPM high and the torque peak lower and longer on the supercharged setup and pump fuel. I did not go with E85 on the Civic as I was unsure if the factory brain would support it and it would not support swapping e85 to pump gas and back. The lower torque keeps stuff from breaking and the higher RPM keeps the engine away from detonation. I got a new direct inject 2.0 Civic and been looking at adding a Type R turbo to it. It is a K20 but the exhaust faces the front of the car. Economy VTEC but probably easily swappable to the Type R dual VTEC-I parts. I will note I do NOT run titanium retainers. As there are wear problems depending on the springs and it is unpredictable. i run chrome-molly and make up for it with a slightly stiffer spring. I can't help wonder at the .660 lift dual spring wear pattern on these packages with titanium retainers. At least on a Honda, when not on VTEC I'm looking at .400 lift, the spring tops walk back and forth across (oscillate) the retainer as they are compressed and ablate the titanium (and visa versa). The higher the lift the more walk. I honestly have no idea why titanium is used on a street driven retainer. Quote:
http://www.superchevy.com/how-to/eng...-lt1-cam-swap/ Note the cam gained 37 HP, and 55ish with CAI, stock heads. EFI_Tuning would know if -13 will need more fuel lobe. I dunno... +30 HP or 6% or so in a shorter injection duration...
