02-02-2017, 05:06 PM | #71 | |
Drives: 2019 Mustang GT Convertible Join Date: Oct 2016
I will own my SS Camaro Vert for 35 months then get rid of it and buy another one just like I did six months ago. Bear |
02-02-2017, 05:12 PM | #72 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Both AOS are under the hood of this Motor Trend press car. Just follow the PCV hoses.
02-03-2017, 10:07 AM | #73 |
Drives: 2017 2SS Join Date: Jun 2014
02-04-2017, 09:36 AM | #74 |
What if I told you the coking wasn't from the unburnt oil from the pcv but from the puff of burnt air from the cylinder the back into the intake tract after the intake valve opens. The hot deposits latch onto the relatively cool material
I'd run one to reduce diluting the intake charge and try to minimize knock. Not to control coking |
02-07-2017, 11:56 AM | #75 |
Drives: 2010 Camaro Join Date: Nov 2009
Here's a good, quick way to see how beneficial this can be:
Take 15 minutes and remove your IM and inspect your own valves personally up close and see. Take some pictures and post them. Now, as for the cause of the coking. No catchcan can prevent all of the coking, but can reduce the rate of formation to a fraction of running w/out a proper system. Now, Nicul15 brings up a good point on this. There is app. 15% of the coking caused by the back filling of burnt exhaust gasses by variable valve timing events to emulate the function of the EGR valves that are no longer part of new engines due to common failures of them. But, the vast majority of the coking is caused by the oil mist it'self as well as other contaminates making contact with the extremely hot valves. Almost none comes from the valve seals as they do their job well, but if you look at your own valves, you will see how with every stroke, the "gunk" is pushed down on the stem as the deposits are drawn up into the guide prematurely wearing them not unlike the days of carbureted engines in the 60's and 70's when coking was an issue, but not nearly as severe as now with GDI. (this was the reason the Gov mandated minimum detergent additives be in all fuel sold for street/highway use). So, there are several things to help reduce the rate and severity of the coking, and a truly effective air/oil separating crankcase evac system is the most effective. The engine oil used is as well. The fuel used has absolutely NO impact at all. Understand folks, one of our Engineers works very closely with one of the largest Synthetic lubricant companies in the World on testing both in the lab and on the road with a fleet of new test vehicles and see;s this all first hand as solutions are worked. And the coking, is NOT the worst side effect of GDI. The contamination and dilution of the engine oil is, and that is the main reason engine warranties form most auto makers have reversed the trend of longer and longer periods. GM, Ford, BMW, and others have dropped from 100k miles, to 36k miles currently. The premature wear and component failures in GDI engines is well documented. And this is where the lubrication labs are working to find solutions more so than the coking. The coking is something that is easy to see even at 5k miles or less, but the internal wear is not evident until severe. And finally, yes, most automakers are installing a form of catchcan on most vehicle engines today with the most common being a sump or containment area integrated into the intake air bridge assy. The next is internally separating the oil from the PCV vapors with internal baffle and separation devices, but this also separates and retains the contaminates that the PCV system in the past removed pretty effectively before they could settle and mix with the oil. There is no way to separate and retain the oil most alone w/out also trapping and retaining the damaging compounds. Then as the Gen5 1LE had a cleanside unit, and the performance optioned V8 Gen6's have 2 catchcans from the factory, but they are only empty plastic containers and no way to drain w/out removing and doing so. So the automakers will probably never accept the cost of a truly effective system or the consumer the need to drain these periodically either. Other changes being attempted are the addition of small port injectors back into the intake ports, but this is too little to make a huge difference, and also contributes to more knock retard as a combustible mixture is again present during the compression stroke. The variable valve timing and fueling events in an attempt to have fuel make contact with the valves back sides has had little to know improvement. So the trend most are using is to either delete the Positive evacuation function of the PCV system as the new LGX V6 does, or to separate and retain not only the oil but the contaminates that cause wear and dirty the oil rapidly. Both result in much shorter engine life due to the accelerated wear. We are hear to provide the data, photos, dyno testing, oil analysis, and more to show form a scientific and technical aspect of all of this. Not to make false claims. There's a ton of misinformation out there, especially when a "talking head" (PR exec) form an automaker is asked about these issues. So throw out all of the hearsay and only present facts and data. These are not the engines of the past, this is a new era and it is not going away. GDI is here to stay as mandated, and all automakers are working to find simple solutions...of which there are none to date. Only bandaids. |
02-07-2017, 01:19 PM | #76 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
http://www.camaro6.com/forums/showth...480249&page=10 ...and FYI the powertrain warranty on these cars is not 36K, it is 60K. |
