04-21-2017, 11:36 PM | #15 | |
Drives: 2016 Camaro 2SS Summit White Join Date: May 2016
04-22-2017, 08:01 AM | #16 | |
On gasoline engine N/A it takes 0.44 lb of fuel per hour to make 1 HP. On Alcohol it take about 1 lb of fuel per hour to make 1 HP. So you can see how the mixture of the 2 determines how much liquid fuel you need to make X HP. There is a Hard limit on the HPFP first then the injectors of how many lb of fuel per hour it will flow. The Lobe helps raise that ceiling a bit but I don't know the exact math at this time. Never Shortcut a fuel system it will bite you in the ass, Engines cost more than fuel pumps and injectors. Ted.
www.jannettyracing.com
04-22-2017, 09:30 AM | #17 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Interesting so in theory on "E100" its a hair over double the fuel demand of pump fuel if I am reading this correctly?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
04-22-2017, 09:38 AM | #18 | |
Drives: Black SS 1LE Join Date: Mar 2017
Aw dang, I imagine how tedious that must have been |
04-22-2017, 12:57 PM | #19 |
Drives: 2017 50th 2SS Join Date: Jan 2017
Good info in this thread. I plan to test the limits of the fuel system on e85. I am procharged and have the flex fuel kit on my car. I am waiting on a zl1 intank pump I have on order then I will be working on max safe power with "e" .
I think somewhere in the low 6xx whp is very possible on e85 and the zl1 pump. Of course results will be posted. |
04-23-2017, 12:04 AM | #20 |
Drives: 2012 Mustang GT, 2017 Camaro 1SS Join Date: Mar 2017
This is my only disagreement but a great post overall. If one has a wideband installed I don't see a need for a dyno tune. Remote tuning with datalogs should suffice.
04-23-2017, 06:15 AM | #21 |
This "30%" incrrased fuel consumption vs gasoline figure I see most use as a generalized reference is that based on 85% ethanol?
04-24-2017, 07:52 AM | #22 | |
Log low side fuel pressure, High side fuel pressure, and injector pulse width. You should not exceed 6ms of pulse width at 7ms they will misfire. High side fuel pressure needs to stay flat any drops in fuel pressure are dangerous. Low side fuel pressure will likely drop to 350 kpa or below with a target of 400 kpa
04-24-2017, 07:53 AM | #23 | |
Ted.
04-24-2017, 07:54 AM | #24 |
Yes sir.
04-24-2017, 09:10 AM | #25 |
Have you seen any positive effect in running an ethanol content of say 85% vs 70%? (NA)
04-24-2017, 09:48 AM | #26 | |
In a supercharged application with high boost, Yes sir. Ted.
04-24-2017, 11:18 AM | #27 |
Drives: 2017 camaro SS 1LE Join Date: Jan 2017
Ted can you expand how the computer can switch between 93 and e85? Or a mixture somewhere in between? I was under the impression that you had to have a 93 octane only tune and an e85 tune in which you would use a handheld to swap back and forth depending on what fuel you are using.
04-24-2017, 11:38 AM | #28 | |
With the sensor the computer can see the actual alcohol content, then adjust the stoich value and timing accordingly. Those days are gone my friend of having to switch tunes and hope you have actual E-85. Ted.
