TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 10-21-2013, 10:14 PM   #155
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
FTI 3200 Tripple disk! I'm lovin it...
RaiderSS is offline   Reply With Quote
Old 06-18-2015, 01:02 PM   #156
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I have a question about torque converters. I keep hearing that after a shift it will help put your engine in its powerband. I currently have the stock converter on my V6, it flashes to 1650 RPM's, but after each shift the TC slip is at 300-400 RPM's according to HP Tuners. I have a Circle D 5C on order, what will happen after a shift now? Will I be higher in the RPM band?
Specs:
V6 with Vortech V3 Centrifugal Supercharger (13 psi)
3.91 gears
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 06-18-2015, 01:11 PM   #157
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
If it's a triple you should lock it, you'll be faster especially since your boosted.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 06-18-2015, 01:43 PM   #158
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Specs:
3.91 gears
Say you install a converter that flashes to 3800. That means when you leave the line, the RPMs will hit 3800 before the car leaves. If your power band was say 5000-6500, that means you will get up and into your powerband quicker. And the looser converter also means that when the RPMs drop on the shift they won't drop as much.
When it comes to shift drop, 1500-2000 RPM drop would be kinda of alot.
1600 stall
Leaves at 1600
Takes some time to go from 1600 to 6500
Will drop to... 4000? 4500?
3800 stall
Leaves at 3800
Takes less time to get to 6500
Will drop to.... 5000-5500?
And you can lock up a triple where it makes sense. Like maybe in 3rd gear after peak torque. This you need to research and experiment with.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 06-18-2015, 02:24 PM   #159
MagnumForceGB
1600 stall
Leaves at 1600
3800 stall
Leaves at 3800
Thanks, it is a triple disk. I shift at 7200 and drop back down to 5000. At 5000 I'm at 5.5 psi, at 6000 I'm near 8 psi, so that should really help.
Old 08-22-2017, 11:08 PM   #160
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Can someone explain to me the difference between stalling and flashing a converter? I have a th400 with a 3k stall from circle d. 600whp, slptvs2300 . Also what do you mean locking the converter?
camarosspower is offline   Reply With Quote
Old 08-22-2017, 11:54 PM   #161
Pro Stock John
Writer
To me...
Stalling up = footbraking and bringing up the engine RPMs.
Flash to me is to wack the gas.
PROJECT HEAVY CHEVY
Old 08-23-2017, 12:48 AM   #162
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Flash is where the converter becomes effecient. Footbrake rpm is usually 1000rpm less or more than flash rpm.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 08-23-2017, 03:03 PM   #163
camarosspower
Thanks guys. So it's probably better to flash the stall at the track? From a roll too? I would guess I couldn't lock my converter since I have a th400? I guess it's a auto/manual valve body. Thanks for the info guys
Old 08-23-2017, 03:45 PM   #164
Bo White
Bo White's Avatar
Correct, th400 is a nonlockup. As in how to race it you will have to play with it and see what it likes.
Totalled:
Old 10-27-2018, 11:38 AM   #165
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Talking TQ's
Anyone used Transmission Specialties torque convertors?
I had a TQ in my 2001 Z28 and was the best mod IMO. I really want one in my 2011 L99. I need someone in the Atlanta area to install.
Thanks.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 10-27-2018, 02:24 PM   #166
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Go Circle D...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 11-23-2018, 07:29 PM   #167
mcbuff52
Drives: 2010 Camaro 2SS/RS A6
What is TM ? My 2010 Camaro with 3200 stall feels like the brakes are applying on moderate throttle also. What is the 6 speed automatic in my car called other than A-6 ?
mcbuff52 is offline   Reply With Quote
Old 11-28-2018, 09:26 PM   #168
mcbuff52
Can anyone explain to me why my 2010 Camaro SS L99 feels as if the brakes are being applied during the 2-3 shift under light throttle? Can this be fixed by tuning the trans.? The trans shifts great under hard acceleration. Also it has a 3200 converter, cam, AFM delete, headers, 3" exhaust w/ Borla mufflers. I'm an old school 4 speed, and carbuerator guy. Help!
Hello First Post, looking at getting one next year Rocketright 5th Gen Camaro SS LS LT General Discussions 11 12-11-2009 07:02 AM
I WILL CHOOSE MY THREADS MORE CAREFULLY, TO POST IN. SQUALO Canada 101 11-22-2009 08:20 PM
Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) TAG UR IT USA - Texas 41 10-19-2009 08:56 PM
Craigslist + Post = unhappy Dealers TiE2000 5th Gen Camaro SS LS LT General Discussions 75 09-27-2009 05:15 PM
