Old 11-21-2023, 05:46 AM   #1
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
ZL1 Headlights
I am a little confused, does a 2020 ZL1 come with a non upgradable led head light or HID? I would like to have something a little brighter than the stock. After searching, some sites show they are upgradable/compatible?
Old 11-21-2023, 08:10 AM   #2
As far as I know, the ZL1's headlights haven't changed since 2017, they're still the same HID units.
2018 Camaro 2SS ó G7E MX0 NPP F55 IO6
Old 11-21-2023, 08:46 AM   #3
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
I have no idea if they are the same but the headlights in my 2024 are stock and fantastic. I was totally impressed with them driving home last week a couple hours after sunset.
SwL_Wildcat is offline   Reply With Quote
Old 11-21-2023, 10:17 AM   #4
w.ross
Drives: 94 Toyota Pickup
I know my 23 still has the HID's, I don't think any of the ZL1's came/come with LEDs.
w.ross is offline   Reply With Quote
Old 11-21-2023, 11:11 AM   #5
CalgaryZL1
CalgaryZL1's Avatar
Ok thanks for the response, I wasn’t sure if they had any refresh of sorts
Old 11-21-2023, 12:33 PM   #6
DangerZL1
Drives: 2023 Black ZL1 Auto
Chevy changed the non-ZL1 models headlights to LED when they refreshed the front end. They didn't want affect the aero on the ZL1, so they didn't change the headlamps. That's what read, but they knew the Camaro was being discontinued and didn't want to spend the $$$.
Morimoto also makes D3 bulbs that are an improvement over the stock ones from reading older posts on this.
Old 11-21-2023, 02:12 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Going to try the Morimoto 6k. I want a little more white light and get rid of the yellow, they seem to be reasonably priced as well.
Old 11-21-2023, 02:15 PM   #8
If it's not too late, I recommend going for a 5500K or 5000K bulb instead. You get the highest lumen output between 5000 and 5500, and the stock unit is 4200K, so 6000K may be too blue next to the standalone DRLs.
Old 11-21-2023, 02:24 PM   #9
CalgaryZL1
CalgaryZL1's Avatar
Yes itís too late, I based my decision off a couple half decent headlight comparison vids, the one video they used the 6000 and it didnít look overly blue. they are shown at 6:10 mark
https://m.youtube.com/watch?v=2dFzk6Daou0
Old 11-21-2023, 04:23 PM   #10
ZLRob
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
LED D3S bulbs. I run them on mine and they have considerably improved the nighttime output of the headlights visibility. I'll shoot a link over here to what I used in a while.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ
Old 11-27-2023, 03:08 PM   #11
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
D3S is bulb size. I've ran Morimoto 5500K since I got the car June 2021, mainly wanted a whiter light.
When I put the bulbs in, I also installed light smoke Headlight Armor. Between both, on a dark back road I can't tell the difference, increase or decrease, in light output.
Morimoto's have been faultless, always come on and never a Popeye. *knock on wood*
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 11-28-2023, 11:11 AM   #12
FrostZ
FrostZ's Avatar
Drives: 2019 A10 ZL1
I run a set of the LED DS3 bulbs in my daily and can agree with ZLRob they have done wonders for me as well. I have a year and a half with easily 20-30k plus night miles on them with zero issues.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
FrostZ is offline   Reply With Quote
Old 11-28-2023, 12:28 PM   #13
ZLRob
ZLRob's Avatar
I can't find the immediate link on Amazon because for whatever reason they are not on there anymore but I got the Panoyu D3S bulbs in the 80 Watt version.
Given the way they look, there are other manufacturers that make the same thing and they look virtually identical.
Like I said, night driving is so much better these days after I replaced them over the HID's.
737 HP/ 779 TQ
Old 11-28-2023, 01:03 PM   #14
infinitereality
On dark back roads, do the LED bulbs have same throw as HIDs? Like on back roads where there's no ambient light? That's always the complaint I've heard and experienced about swapping from HID to LED.
