02-22-2022, 10:19 AM | #1 |
Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Subwoofer Box Options?
Hi i have a 2012 camaro ss I was wondering what box size would fit best for a single 12 inch skar evl. I just need something that will forsure fit and is deep enough for the sub. I don't know the clearance I figured someone else would have done this and can have some edvice for me.
02-22-2022, 01:55 PM | #2 |
Drives: 2011 Camaro ss Join Date: Sep 2021
You might look at subth*^p, I have their single 12” ported box for in a 2012 SS, with the 12 skar SVR running. The only issue is it takes up some room in the trunk and it can be difficult to get into he spare tire well with the box in there.
2011 Camaro 2SS Victory Red
Rotofab CAI, 160 Thermostat, Stainless Works Headers, Livernois Motorsports Thunderstorm Exhaust, GPI SS1, rodmod intake, ported tb by GPI, Remote Tune by GPI, Elite Engineering Catch Can, Rotofab washer relocation, JRE scoop, JRE Trans dipstick, BMR Toe Rods, BMR Trailing Arms, BMR subframe connectors, Polyurethane diff bushing and rear cradle mount's, RSM front crash bar |
02-22-2022, 05:48 PM | #3 |
You ain't kidding. I have to disassemble everything to get to the battery. If I could do it again I would go with a custom fit box behind the seats with dual 12s
02-25-2022, 05:00 AM | #4 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
I have the subth**p dual ported 12" box. Sounds great with the JL setup i have back there but yeah, i have to disassemble the whole thing to get to my battery. I dont see it as a big deal bc i mean, how often do i really need to get to it?
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
02-25-2022, 11:23 AM | #5 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I am not much help because I went with dual 12" and modified the hard cover under the mat so I could get underneath without messing with my speakers.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
02-27-2022, 09:48 AM | #6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
There was a time I had to have the baddest, LOUDEST stereos in my cars. Now that I’m mostly deaf, they don’t seem to have the same appeal.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
02-27-2022, 01:30 PM | #7 |
Drives: 2012 ZL1 Join Date: Apr 2015
I agree with you !! However the stock stereo sucks lol
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
03-02-2022, 01:35 AM | #8 |
03-02-2022, 06:04 PM | #9 |
Drives: 2010 SS Join Date: May 2014
I have this 12” box. Fits snug in the corner of the trunk.
https://www.ebay.com/itm/2012-2015-C...-127632-2357-0 |
Tags |
12 inch, subwoofer |
