08-05-2020, 02:54 PM | #15 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
You are correct, $300.00 is what I was quoted.
08-19-2020, 10:58 PM | #16 |
Well bring to the dealership in the morning to get BCM installed. Got my fingers crossed.
The BCM is right above the brake pedal.Got all the new relays installed. Added a 8 gauge ground from the engine block to the driver side fender. I figured it can't hurt to have an extra. The dealer is saying 2 hours labor @$130.00 per hour...... I will say since I have replaced the starter (2)relays the car has started quicker than it has in about 2 years.. |
08-20-2020, 01:42 PM | #17 |
I pick car up today. Service Writer said that the windows are all working , and everything else seems to be also.... Just $260.00 for program and install.
08-22-2020, 02:05 PM | #18 |
So looks like everything is fixed. I did have to pull fuses F17,F7,F9 with the battery connected. Do this for for over a min.then plug fuses back in. Do up & down for each window and all is good. I now have to just focus if it fixed battery drain. I think it did, because the negative lead did not spark when I hooked it back up. I did a hard reset last night for 12 hours.
08-22-2020, 04:33 PM | #19 |
Also changing to new 2020 BCM PN# 13594614 fix the battery drain.
My battery charger is showing 0.0 Amps. It has never done that... |
07-15-2022, 07:52 PM | #20 | |
Drives: ‘18 SS 1LE Join Date: Dec 2019
07-15-2022, 08:02 PM | #21 |
I'm getting power for my radar detector from the BCM's power lead under the dash
'20 ZL1 1LE A10,
