02-08-2022, 02:34 PM | #1 |
Drives: Fifty Anniversary 2SS Convert Join Date: Feb 2022
6th Gen problems. PLEASE HELP!!!
Please help me! I have a 2017 Procharged Fifty Anniversary 2SS convertible that has a check engine light and these codes pop up when I plugged in my scanner. Also on the dash it'll say "Service Stability control" and then a "P" appears with a wrench under it. Then sometimes it won't up or down shift and the "D" would start blinking. I recently got a new alternator installed and the problem was resolved for a couple weeks and recently started back. I'm at total lost on what to do. Can someone please help me!!!!
02-08-2022, 03:12 PM | #2 |
Thank you Al Oppenheiser!
While a temporary low voltage can cause a bunch of weird false-positive codes, those codes all scream wiring harness or fuse block is cooked/frayed/rubbed/chewed/corroded/wet somewhere.
02-09-2022, 09:47 PM | #3 | |
Soooooo basically I'm screwed lol |
02-11-2022, 06:12 AM | #4 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Headers? If so, look for burnt harness under coolant tank.
02-11-2022, 08:47 AM | #5 |
02-11-2022, 09:13 AM | #6 |
Drives: ‘23 SS 1LE Join Date: Nov 2021
Going down the list:
B2AAA - incompatible code scanner P0700 - transmission requested the MIL turned on. Generic code. U0073 - CAN bus A or high speed CAN failure. Serial messages not received 3 times in 5 seconds. U0100 - lost communication with engine control module U0101 - lost communication with transmission control module P2548 - corrupt torque control information received from ABS controller. Disables stability control All of these are communication failures on the high speed bus. Check the CAN circuit wiring between the ECM, TCM, and EBCM - I’m pretty sure you’ll find the problem there. Worn or stretched wiring harnesses would be my first guess.
2023 2SS 1LE “Red Hot”
Built 7/14/22 Delivered 8/27/22! |
02-11-2022, 09:35 AM | #7 |
Let's start with, "Why was the alternator replaced?"
Sounds like codes may have predated the alternator swap. if so, was the new alternator the proposed solution? Agree with everyone above, the code mix sounds like a wiring/communication issue. Damaged wiring, fuse block, or connector. |
12-14-2022, 09:23 PM | #8 |
Any resolution?
Ive had thisbissue intermittently... seems if the car sits for too long and the battery drains even just a bit, it happens. |
03-14-2023, 02:52 PM | #9 |
Drives: Camaro SS 17 Join Date: Aug 2022
03-14-2023, 03:46 PM | #10 |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
Is you is or is you ain't using your original battery?
Thread Tools | |
