02-07-2022, 07:05 AM | #1 |
Drives: 2017 Camaro Join Date: Feb 2020
What could it be...
Hello all.
OK. 2017. I have been having to undo the negative terminal on the battery to fix this. My AC will not work at times, usually when i turn the car off i can hear the fan running non stop. that means the ac wont work when that happens. AFter i do the negative terminal all is fine. but it has been happening more frequently. what can it be? thx
02-07-2022, 08:32 AM | #2 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Coolant temp Sensor? Low coolant?
02-07-2022, 09:00 AM | #3 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I've heard about this problem related to electrical on my 2007 Impala SS, but the cause in my case is unusual Does your car have a sunroof? IF not forget what I said. In my case the drain railings by the sunroof were blocked and caused water leaking into the car which shorted out the Vent switch of sorts. Very odd issue.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
02-07-2022, 09:30 AM | #4 |
02-07-2022, 12:24 PM | #5 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Water temp not getting up to at least 180 degrees and or taking way to long to heat up to that temp.
02-07-2022, 12:48 PM | #6 |
So it might be the themostat?
02-07-2022, 01:39 PM | #7 |
02-07-2022, 01:57 PM | #8 |
17’ Hyper Blue 2SS
I’ve had this issue in the last few months, specifically when the car starts in 30-50 degree weather in the morning. Temp gauge would be bottomed out not moving, a quick run with the code reader and a quick clear would set the car back to normal, temo was fine and all, no issue, replaced the temp sensor, still happened, replaced the T-stat, still happened. I came to the conclusion that the thermostat just doesnt open fast enough in the cold weather so the sensor panics and throws the fans on full blast. Note I live in AZ so I never really run my heater, but ever since I’ve kept my car at about 85 degrees to get the heater rolling, have not had the issue since.
02-07-2022, 01:57 PM | #9 |
Monterey County Camaros
Mine did the same thing. The fan wouldn't turn off even though the car was off. Did it probably once a month. After the second time I took it in and have the thermostat replaced. Cost about $450. No longer does it.
Follow us on Instagram @montereycountycamaros
02-07-2022, 03:06 PM | #10 |
I forgot to mention. When it does this, the temp gauge does not move even after driving for a while?
02-07-2022, 03:08 PM | #11 |
Just an FYI. When mine does this the AC dont work....heater does. Take the negarive terminal off and everything back to normal.
02-07-2022, 04:41 PM | #12 |
Yes, did you ever swap out the original for a aftermarket cooler thermostat or did someone else? Some of those stats Orings or rubber seals are known to split and slow down warm up. Or the original GM stat is partially open and again slowing down the getting up to temp process or not getting hot enough period, especially during the cold weather.
02-07-2022, 07:18 PM | #13 |
My guess is also the coolant temp sensor or the thermostat (less likely, because a battery disconnect wouldn't fix a stuck thermostat). Just had to get both replaced on wifey's truck
OP, if you have an OBD-II reader, you can read off the codes and hopefully get a clear idea what exactly it is before firing the parts cannon at it.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 02-07-2022 at 10:11 PM. |
02-08-2022, 06:41 AM | #14 | |
Temp sensor is cheaper and easier to get to than thermostat. Load up the oil temp reading on the DIC. That should follow the coolant temp although slower to warm up. If that warms normally I would suspect the sensor over the thermostat. The other thing to do is feel the radiator return hose to see how warm it is. That's old school and I'm not even sure how easy it is to get to on our car. |
